Clutch adjust with cable replacement??
Old Feb 14, 2011 | 08:29 PM
trappermarc's Avatar
trappermarc
Default Clutch adjust with cable replacement??
I stopped by my local dealer to pick up some odds and ends. Got a gasket for my clutch release cover. I'm installing new cables and bars. The parts guy said I would need the seal for the clutch inspection cover. Because I would have to adjust clutch, after the cable replacement. This is my first time changing cables, but shouldn't I just need to adjust the cable??
Old Feb 14, 2011 | 08:32 PM
rjsimmons's Avatar
rjsimmons
The parts guy is incorrect. If all you are doing is swapping cables, then the clutch itself does not necessarily need adjusting. If you have lots of miles on your bike, then it could not hurt, but for now I would say no clutch adjustment is needed.
Old Feb 14, 2011 | 08:44 PM
trappermarc
Cool. I couldn't see any reason to adjust clutch. Only 650 miles on it anyway.
Old Feb 14, 2011 | 08:47 PM
okieboyinaz's Avatar
okieboyinaz
Clutch cable adjustment? Yes! Clutch adjustment? Prob not
Old Feb 15, 2011 | 07:48 AM
ed gien's Avatar
ed gien
Like he said, clutch cable adjustment yes! not clutch. Have 3000 miles and when i swapped cables i just needed to turn adjustment screw a couple turns.
Old Feb 15, 2011 | 01:13 PM
Motorhead England's Avatar
Motorhead England
Cable adjustment only...
Regards..
Old Feb 15, 2011 | 01:29 PM
MacBean's Avatar
MacBean
Thats the stealership for ya. they want to see you stuff you don't need. did he tell you to bring it in for a proper cable adjustment?
Softy 103
Oct 30, 2023 09:14 AM
sg34
Sep 18, 2016 12:16 PM
rdondes
Oct 23, 2013 08:16 PM
ronyd
Mar 19, 2008 10:39 AM
bensonjv
Nov 16, 2006 10:38 PM
