Axle & Fork Cap Wrench Sizes
Old Feb 14, 2011 | 09:11 PM
p51bombay's Avatar
p51bombay
Default Axle & Fork Cap Wrench Sizes
Getting ready to pull everything down for new wheels brakes, etc and don't have the bike handy to measure - could someone provide a wrench/socket size for the following items on a 2010 FXDC?
  • rear axle
  • rear axle nut
  • front axle nut
  • fork top caps
  • Steering stem
Also, will the stem races come off easily or should I get new ones? Bike only has about 2100 miles but if I need to beat on them to remove then I want new ones.
Old Feb 15, 2011 | 12:23 AM
GMDayna88's Avatar
GMDayna88
Check out this link ***dyna models metric sizes database***
https://www.hdforums.com/forum/7911835-post32.html
Glenn
Old Feb 15, 2011 | 08:28 AM
NeverEnoughToys's Avatar
NeverEnoughToys
Don't take out the races unless you're replacing the bearings. They wear as a matched set. I just replaced mine since I was changing the trees. For me, they came out easily with a bearing puller. Not sure the best way to get them out otherwise since the race isn't completely visible from the other side. Definitely use a soft metal though (brass usually).
I have all of these off my bike at the moment. Assuming that your 2010 is the same size as my 2009:
- rear axle: 1 1/8"
- rear axle nut: 1 7/16"
- front axle nut: 15/16" (or 24mm)
- fork top caps: 1 3/8" (or 35mm)
- Steering stem: 1 1/2"
Last edited by NeverEnoughToys; Feb 15, 2011 at 08:46 AM. Reason: Added measurements
cggorman
Apr 5, 2017 04:46 PM
cerelious
Jul 20, 2014 10:08 PM
cavalier2000
Sep 10, 2011 10:03 AM
Malingerer
Aug 17, 2010 07:20 PM
holbrook
Feb 28, 2009 03:02 PM
