New Tank Help
Old Feb 15, 2011 | 05:36 PM
JCK's Avatar
JCK
Default New Tank Help
Im putting a diff tank on my 2009 FXDC.. A 2010 Wide glide Tank.. I know the fuel pump is the same but the top plate is diff. If i change it will my console work are will I have to get a wide glide console? Little help guys..
Old Feb 15, 2011 | 05:59 PM
SuperFastGlide's Avatar
SuperFastGlide
ive seen guys running the wideglide console on streetbobs and other dynas so im gonna say yes, seems they would interchange either way...... but i cant garuntee it will fit...
Old Feb 15, 2011 | 06:00 PM
bberck's Avatar
bberck
Your console wont work without modification. Someone made one work awhile back he had to cut on the dash and use some brackets to mount it.
Also the 2010 WG dash uses the 4 inch speedo not the 5 inch your custom has.
Old Feb 15, 2011 | 06:15 PM
JCK's Avatar
JCK
Fk.. Ill just sell this stuff and an paint mine.. Crap crap crap..
Old Feb 15, 2011 | 09:39 PM
U-234's Avatar
U-234
he Dynas have used 3 tanks from 2004 to 2010.
Tank 1 = FXD, FXDX, FXDC, ‘07 FXDSE
Tank 2 = FXDB, FXDL, ‘08 FXDSE, '10 FXDWG
Tank 3 = FXDWG to '08, ‘06 FXDI35, ‘07+ FXDC, ‘08+ FXDF, '09+ FXDFSE
All the tanks will mount to the bike.
The consoles and speedos won't mount to every tank.
Tank 1 has no speedo spot.
Tank 2 is the smaller tank and uses the 4 inch speedo.
Tank 3 is the larger tank and uses the 5 inch speedo.
The WG used tank 3 through '08. When it was brought back in '10, it went with tank 2.
There has been discussion in a change in one of the newer tanks because of a part number change.
rbartick
May 29, 2017 07:25 AM
paullavery
May 19, 2011 06:36 PM
melbharley
Jan 27, 2011 10:05 PM
glide05
Jul 10, 2008 09:38 AM
98fxd
Aug 24, 2005 07:58 PM
