07 Dyna Crank question
Old Feb 20, 2011 | 10:16 PM
roadrunner68's Avatar
roadrunner68
Unhappy 07 Dyna Crank question
I bought this bike a couple of months ago. It seems to run ok. No noises just an oil leak at primary. Well,I opened up the primary and found a mess. Starter ring gear missing a tooth and this black stuff. Well,after fixing the ring gear.decided to upgrade to the Screaming Eagle compensator,figuring this is what caused to starter issue.
When I removed the stator,I found the black stuff was the stator magnets. The piece from the starter ring gear was inside the stator. It also damaged the rotor,eventhough it still charged. I bought a used rotor and installed. Figured I had it licked.
I decided before I installed the primary cover I would turn it over to make sure all was ok. Noticed the bolt in compensator had some runout.
I placed a dial indicator on the crank end of compensator. I get around .025" I know this exceeds the limit. If I have this much runout on this side,what are the odds that this is the same on the cam side? Had thought that possibly the rotor damage might have caused the crank runout issue only on the compensator side.
If the crank is twisted it would be the same on the other side also? Appreciate an expert opinion.
I'm to the point now,since it still has oil pressure,that I will put it up for sale and cut my losses now. Tom
Old Feb 20, 2011 | 11:01 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
If you are going to sell it then what do you need an opinion for? Then again if it were me I would pull the crank and have it repaired/replaced with a balanced/welded one and re-cam the engine and do a big bore kit. But if you have .025 on one side I really doubt the other side is true. Sounds like somebody rode that bike pretty hard.
Old Feb 21, 2011 | 12:19 AM
HemiOrange's Avatar
HemiOrange
Just fix it. I could never sell a bike, with a known problem, to a bro without first telling them the truth. Maybe I'd trade it in, but I'd never sell it outright.
I've been through similar situations and just ate it at my expense.
Old Feb 21, 2011 | 02:14 AM
Los11's Avatar
Los11
.025 is alot of runout I would still check the cam side and see, I am not sure if the rotor problem caused that runout on the compensator side but checking the cam side may tell you more.
WMX124
Dec 28, 2019 11:41 PM
huddy
EVO
24
Mar 10, 2015 08:40 PM
williamf57
EVO
21
May 11, 2013 06:27 AM
sea-n-spots
Apr 24, 2013 12:40 PM
JackShafted
May 21, 2008 11:02 AM
