Accesory Wire
Old Mar 7, 2011 | 08:12 PM
samp81's Avatar
samp81
Default Accesory Wire
Trying to install a set of J&M speakers to my Bob. The Instructions say to connect the power wire to a switchable power source. I received some advise to connect the power source to the accessory wire. Unfortunately, I do not know where the accessory wire is located (can not get a service manual until tomorrow). Does anyone know where the accessory wire is located?
Old Mar 7, 2011 | 08:44 PM
Aaron 09FXDB's Avatar
Aaron 09FXDB
I have a 2009 Street Bob. Mine was under the seat. Black square multi pin connector. I cheated and paid $15 for a (I believe softail) accessory HD plug-in cig adapter. Use the plug to plug into the harness....then run the wires to whatever you'd like....very easy and clean set up. I have a fuel pack on mine so I had to really dig into the wires to find it. Had a rubber plug fitting over the end of it. Hope that helps.
Old Mar 7, 2011 | 08:48 PM
SteveO-ll's Avatar
SteveO-ll
Old Mar 7, 2011 | 09:12 PM
nevil's Avatar
nevil
Aaron- is that cig adapter fused?
Old Mar 7, 2011 | 10:29 PM
Phrogman's Avatar
Phrogman
+1, it is under the seat on the 2009 Fat Bob too. I used it to power my 12v garage door opener that I tucked under my console. You can go to just about any dealership, autoparts store and probably a Fastenal, etc...to get the parts needed to make a Deutsch connector for it as well. It's not hard to do if you can crimp connectors on wire.
Old Mar 8, 2011 | 02:54 AM
8541hog's Avatar
8541hog
The Accessory wire is Orange with a White tracer if you want to go that way.
Old Mar 13, 2011 | 08:03 PM
samp81's Avatar
samp81
Finally found it. It was tucked down under the the rear brake light harness.
Old Mar 13, 2011 | 09:17 PM
Aaron 09FXDB
Sorry didn't see your question. NO the cig adapter itself isn't fused. The accessory line is fused at the panel, but I have thought about throwing in a inline fuse any way...just to be safe, I guess it couldn't hurt.
PaGuy610
Jul 30, 2018 11:32 AM
jackod
Feb 11, 2013 09:01 AM
TedMan
May 25, 2011 08:15 AM
Foodog
Sep 29, 2010 11:18 AM
jackinthebox
May 30, 2009 11:24 PM
