Steering Head bearings?
Old Mar 10, 2011 | 08:00 PM
Jeff W's Avatar
Jeff W
Default Steering Head bearings?
Explain what happens if to tight, and if to loose.
Old Mar 10, 2011 | 08:02 PM
ackman1968's Avatar
ackman1968
Too tight and you get very poor low speed handling as it "binds" and makes it slow to react. Too loose and you get the dreaded clunk often accessorized by head shake.
Old Mar 10, 2011 | 08:31 PM
misfitJason's Avatar
misfitJason
Way to tight the bearings seize and bind I.e. You die. Too loose you die
Old Mar 10, 2011 | 08:59 PM
Jeff W's Avatar
Jeff W
Good to know lol. im just now going to be getting around to checking them, once i got the apes on the front feels loose and wobbly, im thinking the steering head bearings are my fix, just wanted to know how critical my adjustments are going to be. thought in tighten them just a hair and test ride to see what it does for my problem.
New tires, new wheel laced on last fall, wheel trued up and balanced, all thats left is those bearings.
Old Mar 10, 2011 | 09:36 PM
dsiltman's Avatar
dsiltman
Do a search on steering head bearing adjustment or fall away to do it without guessing at it.
Old Mar 10, 2011 | 10:04 PM
jmeiers's Avatar
jmeiers
Thumbs up
When I put my front end back together after all the powdercoating, I just snugged the neck adjuster up to what felt right and then torqued down the stem nut proper and while I was out for a test ride in the neighborhood, when I would come to a stop, it would make this bad shudder as the rpms came down to idle. I just loosened the stem nut and tightened the neck adjuster another half turn and it is now perfect.
Old Mar 10, 2011 | 10:05 PM
Jeff W's Avatar
Jeff W
Oh im going to follow the manual and do the fall away, I imagine the new heavier bars have changed the fall away and the bearings would have to be adjusted to get it back where it needs to be. anyhow im crossing my fingers.
Old Mar 10, 2011 | 10:08 PM
Jeff W's Avatar
Jeff W
Originally Posted by jmeiers
When I put my front end back together after all the powdercoating, I just snugged the neck adjuster up to what felt right and then torqued down the stem nut proper and while I was out for a test ride in the neighborhood, when I would come to a stop, it would make this bad shudder as the rpms came down to idle. I just loosed the stem nut and tightened the neck adjuster another half turn and it is now perfect.
Cool, glad that worked, i cant imagine this being such a hard thing..i just have to stop and buy an 1.5" socket to fit that nut as i dont seem to be able to find mine...gonna try and get this done in the morning and get a test ride before i leave for work in the afternoon.
Old Mar 10, 2011 | 10:17 PM
aclundwall's Avatar
aclundwall
My Superglide, purchased brand new at the end of January, needed the steering head bearings adjusted right out of the gate. I could tell on the ride home from the dealer that they were loose.
Be careful when you do it... you have to loosen the LOWER triple clamp fork tube clamps, so that when you tighten the stem nut it pulls the lower triple clamp up. I tapped mine with a plastic mallet as I'd tighten the adjuster, so that the clamp moved up. If you don't loosen the triple clamp, tightening the stem nut just binds the whole mess up.
To me, having worked on dirt bikes for years it seemed counter-intuitive to loosen the LOWER triple clamps... but that's the recommended procedure.
Old Mar 11, 2011 | 05:24 PM
Jeff W's Avatar
Jeff W
Well, I adjusted the steering head bearings, by the book, first before I started the fall away was immediate, so it needed done. First thing I found was 2 of the screws for the fork clamps was far from tirade properly, so once I got done I double checked everything, got it off the jack and went for test ride, it's better, I can get up to 80 and cruise 70-75 very comfy. But starting at 80 or anything above it gets to feeling funky.
