Heat Demons
Old Mar 29, 2011 | 07:19 AM
mirror's Avatar
mirror
Default Heat Demons
Just about it install Heat Demons on 2009 super glide custom
Looks basic to do But where do you get power from to run them ?
Old Mar 29, 2011 | 07:50 AM
TimBone's Avatar
TimBone
Easy job to do dude. Have used them twice now and they work great!
You will tap in to one of the wires from the left hand side
and I would suggest using solder and heat shrink to make it a
good connection and waterproof.
Old Mar 29, 2011 | 08:52 AM
8541hog's Avatar
8541hog
The Orange/White wire is your accessory power.
Old Mar 29, 2011 | 01:07 PM
mirror's Avatar
mirror
Went together good only thing is just cant find the Orange/White wire says its near the battier ??
Old Mar 29, 2011 | 03:05 PM
8541hog's Avatar
8541hog
You can find it all over the wiring harness but it does run on the throttle side of the bars
Old Mar 29, 2011 | 04:27 PM
dynabobster's Avatar
dynabobster
Have you had any problems when gluing the grips on or the grips coming loose because of the heat? Are you guys even using glued on grips? I just wanted to add the heat Demons and reuse my grips, on a tight budget and did not want to buy new grips.
Old Mar 29, 2011 | 04:31 PM
8541hog's Avatar
8541hog
Just curious, what does a set of these Heat Demons cost?
Old Mar 29, 2011 | 05:04 PM
TimBone's Avatar
TimBone
Not using the glue bro.
Luckily the grips are held nice and tight by
the switch house. Have not had any problems.
Old Mar 29, 2011 | 05:06 PM
TimBone's Avatar
TimBone
Got my sets from eastern performance for just under $100 and free S/H.
Really like them and would definitely recommend them.
--Nice USMC points cover!--
Old Mar 29, 2011 | 05:36 PM
mirror's Avatar
mirror
After searching the forum found a 4 pin harness under the seat 2 hot two ground rigged up a wire joiner to the hot
wire so I wouldn't cut in to a unknown wire Works so i hope i got it right . Apparently there is a HD adapter to run accessories so you don't have to cut in.
Paid 129.99 here in Ontario for the heat demons at ( Royal Distributing) working good so far but still have a little snow on the ground.
Thankyou All for the help
