Idle adjusting tool
Old Apr 1, 2011 | 12:29 PM
07bobber's Avatar
07bobber
That screw came loose on me one time so i used some blue loctite and adjusted it back to the normal idle, and checked it using my tuner and laptop
Old Apr 1, 2011 | 12:43 PM
bobnehoc's Avatar
bobnehoc
Originally Posted by 8541hog
Drew, did you just hand out loaded guns to a room full of curious people?
That is a good one....+1
Old Apr 1, 2011 | 02:29 PM
Spanners39's Avatar
Spanners39
So it does adjust the idle then?
This one has been adjusted by the PO and the idle is that point where your eyes bounce about in the sockets, just need to bring it down by 100rpm.
Old Apr 1, 2011 | 03:59 PM
07bobber's Avatar
07bobber
the idle adjuster is there just for that but these engines have a certain spec for the idle between 920-1100 i think (NOT POSITIVE)
Old Apr 1, 2011 | 05:08 PM
Spanners39's Avatar
Spanners39
I need to get to under 1000 and it will be sweet.
Old Apr 1, 2011 | 07:21 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The top end needs more oil than the twin cam can provide at a 900 rpm idle. I believe idle should be about 1100 rpm. But, if you want to turn it down so it sounds bitching be my guest. Just remember the top end needs more oil than can be provided at that rpm.
Drew
Old Aug 26, 2018 | 07:43 PM
Capt_Salty's Avatar
Capt_Salty
Drew
WOW! Many Thanks for that info. I was just messin' with my '08 FXD wanting to drop the idle to about 800... now I know better!
TheGit12
May 12, 2016 04:02 AM
macmolly
Jul 16, 2013 01:03 PM
2000FiveOh
Aug 6, 2009 10:11 PM
Robottom
May 5, 2009 05:23 PM
King FLH
Exhaust System Topics
Apr 13, 2007 09:42 AM
