Idle adjusting tool
Old Mar 31, 2011 | 10:13 PM
Spanners39's Avatar
Spanners39
Default Idle adjusting tool
I need to adjust the idle on an efi 2005 Road King and the dealer keeps telling me its a security torx and I can buy one from a hardware store BUT IT ISN'T!!!!!
A Torx has 6 points and the idle adjuster has only 5...anyone know where and how I can get the tool?
Old Mar 31, 2011 | 11:17 PM
8541hog's Avatar
8541hog
Can you post a pic of it? I had not heard of the idle being mechanically adjustable on EFI bikes.
Old Apr 1, 2011 | 04:52 AM
Spanners39's Avatar
Spanners39
It sure is, look behind the back of the air box, there it a metal piece that touches on the back of this here screw when you shut the throttle.
It looks like a torx with a pin in the middle and sits in the 5 o'clock postion when you look at the back plate of the airbox with the cover off.
Can't get a pic as the bike isn't here just now.
Old Apr 1, 2011 | 05:09 AM
bobnehoc's Avatar
bobnehoc
It sounds like a security screw. We have them at work. We had purchased a computer tool kit that had those bits as well as regular torx. You should be able to buy them online. The pin in the center is what makes it a security screw because you can't just use a small straight blade or a regular torx screw driver.
Old Apr 1, 2011 | 05:41 AM
dyna rider's Avatar
dyna rider
Default Security Torx
http://www.amazon.com/Torx-Wrench-Ta.../dp/B0002SQ45K
Old Apr 1, 2011 | 10:10 AM
tarheelrdr's Avatar
tarheelrdr
If this is EFI bike, that is not an idle adjustment screw. It is for adjusting the throttle plate that effects the IAC. I believe the idle can only be adjusted through the ECM with a tuner such as a SEST or equivalent . Others with more knowledge might chime in on this.
Old Apr 1, 2011 | 10:15 AM
8541hog's Avatar
8541hog
That has always been my thought as well, which is why I asked for a pic, that and I am 3000 miles from my bike.
Old Apr 1, 2011 | 10:31 AM
Uncle Larry's Avatar
Uncle Larry
+1 ... Yep .... What he said!
Old Apr 1, 2011 | 10:38 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Actually, you can turn the screw although it is not recommended. On the side of the intake manifold where the a/c mounts, there is an aluminum plug that is covering this screw. Drill out the plug and you will have access to the screw. Careful not to drill out the head of the screw. I cannot remember the size but it is there.
Drew
Old Apr 1, 2011 | 10:45 AM
8541hog's Avatar
8541hog
Drew
Drew, did you just hand out loaded guns to a room full of curious people?
