How are you lifting your 06 Dyna?
Old Apr 3, 2011 | 06:07 PM
superb70's Avatar
superb70
Default How are you lifting your 06 Dyna?
I own a Sears motorcycle jack that I have used on my 85 Iron head Sporty & 93 Flhtc with no problems but I can not use it to lift my 06 Dyna due to the uneven lower frame! So what are you guys using to get your Dyna off the ground?
Old Apr 3, 2011 | 06:36 PM
wornknobby3's Avatar
wornknobby3
how uneven is it? can you shim one side with something soft to not scratch the frame like carpet.. i use old peices of square carpet that we got from an old demo show, works awesome since its soft and flexes, while the jack holds the weight sturdy
Old Apr 3, 2011 | 09:01 PM
SC-Longhair's Avatar
SC-Longhair
Use the forum search function to find a thread I started called "sears red jack modification". problem solved.
Old Apr 3, 2011 | 09:07 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
+1 do that. SC I am doing mine this Summer. I think you should seriously look at a patent on that style jack. To the OP, harley makes plastic jack adapters that fit on the frame but the red sears jack modification is way better.
Old Apr 3, 2011 | 09:17 PM
rjheff's Avatar
rjheff
I bought the H-D adapters for my Sears red jack. They cost roughly $20.
Old Apr 3, 2011 | 09:31 PM
SC-Longhair
Those adapters are the anti-christ.
Plus, the jack mod costs about half that.
Old Apr 3, 2011 | 09:48 PM
rjheff's Avatar
rjheff
I'm trying to keep the jack original.
Old Apr 3, 2011 | 09:52 PM
Comingapart's Avatar
Comingapart
I really dislike motorcycle jacks. I usually use a harbor freight engine lift and lift the bike by the shockmounts. Done it for years on various Dynas and Sporties.
Old Apr 3, 2011 | 09:55 PM
rjheff's Avatar
rjheff
The $499 HF1000 lb motorcycle lift is on sale for $299 with the right coupon.
Old Apr 3, 2011 | 10:55 PM
Dynaglide68's Avatar
Dynaglide68
I have the same jack i put a 2x4 piece wood in front of each tire then ride up on them the jack works great after that ...
