Oil cap shooted, wtf?
Old Apr 6, 2011 | 10:44 AM
goooze's Avatar
goooze
Angry Oil cap shooted, wtf?
HD Dyna Sport Glide FXDX 2000 year, odometer: 2200 km.
My first ride in this season. After 30km of my ride due to unknown reasons, that require further examinations, the oil tank lid popped up by itself.
Who can explain it?
Old Apr 6, 2011 | 10:49 AM
renegado's Avatar
renegado
The same thing happened to me. I`ve tried changing de o`ring but that didn`t fixed. I`had to change the filler neck.
Old Apr 6, 2011 | 11:00 AM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
Mine did that a couple times after I washed it. it was worn out replaced it with a new cap,never had an issue again.
Old Apr 6, 2011 | 11:02 AM
goooze's Avatar
goooze
I thought the problem is in my RSD air filter (cylinder ventilation).
But I'm not sure.
Old Apr 6, 2011 | 11:09 AM
tinker1's Avatar
tinker1
This happened to me years ago while riding my Heritage across Wyoming... Only happened that one time, and the bike was still pretty new.
The only thing I could come up with as to the reason, was the excessive wind - I was rolling along on I-80, and had a really strong cross wind the whole way through the state. The wind was coming from my left, and the oil spigot was on my right, so I thought that maybe enough of a low pressure on the side away from the wind made the plug pop out. Sounds crazy I know... but it was all I could come up with.
Old Apr 6, 2011 | 11:15 AM
8541hog's Avatar
8541hog
Just curious, do you consistently run at high RPM's, that would create high oil pressure which could cause it if the seal is weak. Does your air cleaner not have the crankcase ventilation? Did you block it off?
Old Apr 6, 2011 | 11:18 AM
goooze's Avatar
goooze
Originally Posted by tinker1
... [skiped]
Mysticism!
Today was windy, +5C. May be I need to replace the cap 'cause my bike is 10 years old and the cap is rubber?
Old Apr 6, 2011 | 11:25 AM
goooze's Avatar
goooze
Usually I run at 3-4 RMP, not more. It's ok?
crankcase ventilation - ok, I didn't block it. But I'll check it.
rodethedragon
Exhaust System Topics
Nov 16, 2010 03:25 PM
Morse
Oil Archive (no new posts)
Aug 11, 2010 11:10 AM
LebHDMan
May 28, 2010 04:32 PM
sportstersweetie
May 21, 2008 04:06 PM
Dave06FXDLI
Mar 4, 2006 06:30 PM
