throttle help
Old Apr 21, 2011 | 04:21 PM
nutter's Avatar
nutter
Default throttle help
so heres the problem i had alot of play in my throttle, so after finding an old thread and watchin a few youtube vids i adjusted it.(one closest to me) i no longer have play and it snaps rite back no problem but now it seems like i rev higher quicker and need to shift lower speeds than before...what did i do and how can a fix it?
Old Apr 21, 2011 | 04:45 PM
Spanners39's Avatar
Spanners39
If there was slack in the cable you would have been missing a lot of horsepower...tightening the cable can seem like a performance upgrade if it was bad enough before.
You'll get used to it.
Old Apr 21, 2011 | 05:24 PM
USMAMule's Avatar
USMAMule
+1 Depending how bad it was, it probably feels like a hair trigger now. "play" in teh throttle is a bit of a personal preference thing, but I'd say if you had more than about an eighth of an inch before you felt the revs increasing you had a very sluggish response and were definitely missing the top end of teh twist so to speak.
Ride it like you stole it and enjoy.
USMAMule
Old Apr 21, 2011 | 07:28 PM
nutter's Avatar
nutter
i def feel the throttle responce better but im haveing to shift at lower speeds than i usally haveto
Old Apr 21, 2011 | 08:04 PM
archergodwin's Avatar
archergodwin
Why do you think you're having to shift at slower speeds? Sound of the engine? Tach reading?.... ???
Old Apr 21, 2011 | 08:32 PM
nutter's Avatar
nutter
tach and speedo reading
Old Apr 21, 2011 | 08:39 PM
archergodwin
Only thing I can think of is that your engine is now reving faster because you are able to give it more throttle... getting to a forward speed sooner, which might equate to having to shift sooner... there's a lot of pieces of the puzzle missing on this one....
Old Apr 21, 2011 | 09:42 PM
A1ACruiser's Avatar
A1ACruiser
Go back to the drawing board. Loosen up the throttle cable and make another adjustment to your liking. I made 3 adjustments to get mine exactly where I liked it.
Old Apr 22, 2011 | 01:26 AM
Andjh123's Avatar
Andjh123
I'm sure you'll get used to it soon enough. There's absolutely no correlation between slack in the throttle and shift points or how quickly it revs. Probably just a lot more sensitive now which makes everything seem like it's happening sooner/faster.
Old Apr 22, 2011 | 02:48 AM
Spanners39's Avatar
Spanners39
Yup, a bigger throttle opening for the same amount of wrist movement will feel like you are changing up at lower speeds...it won't change your gear ratios.
Ozark Joe
EVO
18
Dec 20, 2015 09:07 AM
zachpeed
Mar 2, 2014 10:32 PM
KDagostino
Apr 8, 2013 08:44 PM
KDagostino
Exhaust System Topics
Apr 8, 2013 07:21 PM
waterman7474
Aug 30, 2006 09:42 PM
