2011 FXDWG Exhaust
This is good information to have. I was under the impression that the EFI on these bikes was more akin to the old school ROM based program (hence the need for a flash or download from the dealer). It sounds like the system has a closer resemblance to that of the modern day OBD-II automotive systems, wherein slight, yet progressive changes are made to the fueling and spark advance tables over the course of several hours of run time (RAM based program).
If I understand you correctly, the open loop tables are essentially interpolated or augmented from the data acquired while in closed loop operation. I would assume then that the download simply modifies the algorithm with which the fuel and spark advance values are derived from the (dynamic?) table.
As long as I am not doing irreparable damage by giving the ECM its due time to “recalibrate” itself, I can live with it.
Are we on the same page now, or am I way off base?
Now, the ECM will look at the O2 readings and says that with F fuel the O2 reading should be Q. If it's richer than Q, then the ECM will note this and adjust F fuel by a certain amount to try and make what it thinks Q should be. Now it may be different for Harley's Delphi system, GM's Delphi system calls these tweaks in Closed Loop situations Short term Fuel Trims (SFT) and they are changing constantly as you drive based on the feedback the ECM gets from the O2s.
The ECM takes these SFT and uses them to determin fueling needs when the ECM enters Open Loop and starts ignorning the O2 sensors. In GMs Delphi systems these are called Long term Fuel Trim (LFT). When the ECM enters Open Loop, the fuel trim locks in at the LFT value. When we tune GMs, we tweak the base fuel table so that the SFTs adjustments are small and the LFT locks in as close to 0 as possible.
Now there are other things that adjust F fuel. Engine temp (for cold starting), Air Temp (hotter air is thinner air thus requires less fuel), and Barrametric pressure (for higher elevations the air is thinner thus needing less fuel) but unless modifications have been done that may have some affect on fueling needs under these conditions these tables are left alone.
Again, I've been told the Harley Delphi system opperates in a similar fashion but I don't know the details.
It will be most useful to have a little more technical background on the EFI system when I speak with the dealer. I've always found it to be useful in negotiations when I know a bit more about the product (technical details anyway) than the salesman.
Anyways, I'm planning on heading in to the dealer on Friday afternoon... and hoping to come home with another Harley. Now, if only they had the 40% off merchandise deal that was going on when I bought the Nightster...
Thanks again for the explanation.
Happy riding
Happy riding
Going in tomorrow... coming home with a Sedona Orange or Vivid Black and flames Wide Glide. I probably have a week before the pipes will go on.
I did have a thought... does anyone know what the O2 sensors voltage output should be at 14.7:1? I could always check it that way. Maybe a before and after reading? It would be easy to set my Fluke for peak and hold and take a loop around the block. I could then change the exhaust and repeat. Then compare notes.
I have the same bike V&H staggered big shots SE tunner Highflow air, bike is fast sounds great, I'm on the throttle all the time never turned a LEO's head.
