My engine also dies randomly
Old May 6, 2011 | 08:47 PM
Bobber Jake's Avatar
Bobber Jake
Default My engine also dies randomly
I could be just cruising down the highway and it will die. I will have all my power( lights,speedo,ect.) just the engine dies. If I switch the run/off switch and the hit start button it will start right back up even while I am still coasting. Anyone know what the problem might be. Its a 07 fxd.
Old May 7, 2011 | 01:36 AM
Ratbob's Avatar
Ratbob
I've seen more than a few of these randomly intermittent problems on this forum root caused to the electrical connection to the battery. I would tighten both connections to the battery, along with the chassis ground stud(s). If that doesn't fix it check your codes to see if the ECM has flagged a fault.
Good luck, and be sure to post back what you find!
Old May 7, 2011 | 03:17 AM
upnorthbiker's Avatar
upnorthbiker
Hi BJ,
When I had my 07 Dyna it would just die, then restart at a push of the button. I had the ECU upgraded as in the attached sheet. Hope this helps.
Regards,
Jeff
File Type: txt
Old Jun 1, 2011 | 01:38 PM
jstdadd's Avatar
jstdadd
Default Engine Dies
I just got towed last weekend for this very reason. It was the System Relay, a $5.00 part. On my Heritage Softail, 2006, this is a grey box about 3/4 of an inch square that is on the fuse block, under the seat.
For $5.00, just replace it and see if it fixes your problem. It simply plugs in.
The System Relay controls the fuel pump on an injected engine, and if bad it simply shuts off the fuel. There might be a code for fuel pump, pressure or something similar.
kvandermeer
Aug 9, 2017 12:29 PM
kwwn15
Jan 30, 2016 09:25 PM
bryan-37@hotmail.com
Jun 7, 2012 08:02 PM
chuckieb
May 27, 2010 09:57 PM
Olep228
Dec 3, 2006 02:37 PM
