Sheared Off Rear Pulley Bolts
Old Nov 12, 2013 | 12:17 PM
  #181
Chicago Fan 33's Avatar
Chicago Fan 33
I cant believe this is still going on. It happened to me many years ago and there was a "Service Bulletin", All Dealers knew about this problem and in my case everything was R/R at no charge. The Factory Rep told me because my local HD Dealer changed my pulley and added chrome bolts that were not available for my 06FXDBI that was the problem and replaced with the stock grade#8. He claimed the chrome bolts were not as hard as the chrome. This thread has been around a long time and if you look up older posts you will find the Service Bulletin. I also now have marked the position of the pulley bolts and it is one of the first things I check before getting out. Glad you didn't go down.....
Old Nov 12, 2013 | 01:12 PM
  #182
Warp Factor's Avatar
Warp Factor
There's a remote chance that Harley will cover it or provide some assistance, if you take it to a Harley dealer and have the repairs done there. Sometimes they will do that with known chronic problems. Have the repairs done elsewhere, and they won't touch it with a ten foot pole.
When I had some widely known chronic problems repaired on a 2006 by an indy, because it broke down 1/2 block from his shop, that was the excuse they used and stuck with. Some people have gotten the same problems repaired for free, or with some kind of cost sharing agreement by going through a dealer.
Old Nov 12, 2013 | 04:54 PM
  #183
Lakerat's Avatar
Lakerat
I use ARP 614-1750 $22.54 for a set of 5 from Summit Racing. 12pt stainless with yield strength of 170,000psi. Your length may be different, mine on both bikes are 7/16-14 X 1 3/4. Standard grade 8 is 130,000psi.
http://www.summitracing.com/parts/ar...1750/overview/
Old Nov 12, 2013 | 06:55 PM
  #184
WMX124's Avatar
WMX124
It's my understanding that it's not so much the strength of the bolts that is the issue but rather the fact that they are backing out of the hub.
They can be made from top notch tool steel but if they back out of the hub they will still **** something up....
Seems to me like the issue is with the installation of the bolt itself. (application of thread locker). I find it hard to believe that 65-75 ft-lbs of torque is overloading a 7/16 Gr 8 bolt. I think HD recommends replacing the bolts because they come with thread locker on them. That way you can assure you have the right amount applied to the bolt.
Old Nov 12, 2013 | 07:45 PM
  #185
Lakerat's Avatar
Lakerat
Just my thoughts, take it for the $.02 they are worth. There has been discussion in this thread about bolt quality as well as proper installation. The bolts in my link would be an upgrade for not that much money. They are shiney and come with the washers as well.
Old Nov 12, 2013 | 08:32 PM
  #186
PoCoBob's Avatar
PoCoBob
There has to be something to this. I have replaced my rear tire twice, once at the harley shop and once I did it myself. Both times the pulley was removed and reinstalled using the same original bolts. I marked the bolts both times with a Sharpie and tonight after reading this I went out and checked them again. Nothing has moved and nothing moved the last time either. I don't know what is causing this to happen to so many bikes but I no longer believe the stock bolts have to be replaced. I agree with the above quote that it could be a thread lock issue, the other thing I wonder is what would happen if the bolts were over tightened? The rim is aluminum and it wouldn't take that much to weaken the threads in the rim.
Old Nov 13, 2013 | 07:09 AM
  #187
mattVA's Avatar
mattVA
Do yourself a favor and replace them. .if Harley says a bolt is a one time use, they mean it. Bolts stretch when torqued. The logic of "it hasn't happened yet" isn't good logic. Why chance a catastrophic failure and your health over a few bucks.
Old Nov 13, 2013 | 07:42 PM
  #188
PoCoBob's Avatar
PoCoBob
I'll have to check my service manual but I am fairly sure I looked and it says nothing about needing to replace the bolts. Either way there are way too many people having this problem so something is not right.
Old Nov 13, 2013 | 09:51 PM
  #189
NSCoyote's Avatar
NSCoyote
fi the pulley comes off for replacment or servicing, replace the bolts with QUALITY bolts, loc tite and torque them in. Bolts are cheap wheels, belts, pulleys and possably your life is not. Grade 8 bolts definitly not chrome as the chrome process changes the metalurgacl integrity/ weakens it
Old Nov 13, 2013 | 11:10 PM
  #190
FreddyP's Avatar
FreddyP
Don't know enough about what chrome process does to the bolts--- but I sure hope Harley does since they sell chromed replacement bolt kits (Chrome Hex Head Hardware Kit for Rear Belt Sprocket-94773-07) as an example. Just saying...
For me the real issue is knowing...anytime the pulley comes off...it's time for new bolts. NSCoyote is right, bolts are cheap :-)
