Baffel removal
Old Oct 27, 2006 | 01:23 PM
jeff243's Avatar
jeff243
Stage III
Default Baffel removal
just bought a 06 wide glide.
any wisdom in removing the baffels from the exaust?
Old Oct 27, 2006 | 03:04 PM
RWP's Avatar
RWP
Default RE: Baffel removal
You need baffles for your bike to run properly.
RWP
Old Oct 27, 2006 | 03:14 PM
gbm's Avatar
gbm
I bought a pair of "take off" mufflers on e-bay (cheap) and punched the baffles out of them. Just like I had read in this forum a long time ago, they kind of whistled at an idle but sounded OK otherwise. I noticed no significant difference in performance. I replaced them with some Khrome Werks mufflers when I could afford it.
Old Oct 27, 2006 | 03:30 PM
RudeDog's Avatar
RudeDog
The baffles are not removable. You could drill a hole in them (I would recommend 1" to start with) to get more sound and slightly better performance (punching will get you the whistle as stated above by gbm). The best way to do it would be to buy new slip-ons.
Old Oct 27, 2006 | 04:07 PM
gbm's Avatar
gbm
The baffles are removable, and you could gut the whole can if you wanted to. The baffles I removed were in the center of the perforated core tube and looked like automotive freeze plugs. I made a plug on a 12" pipe nipple that just barely fit in the core and whanged on it with a 3 lb. sledge. 4 hits and the baffle was on the floor. They are only spot welded in place.
Old Oct 27, 2006 | 09:46 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: gbm
You did NOT remove the baffles............. Just the the plug.
I did the same thing (drilled mine out), and with a K&N full flow air cleaner, and TFI, am producing 74 hp / 78 ft/lbs torque on the Dyno.
2-1 is what I will end up putting on when I have the money...... Great sound, more torque and hp + classic harley look (look at the older models).
DougJ
Old Oct 27, 2006 | 10:30 PM
dynamolowrider's Avatar
dynamolowrider
tack a 1inch key hole saw and drill them out then use a die grinder and smooth it down to the wled then the hole baffel will slide out its about a foot long .if you dont grind the rough edge down it will be hell to get the baffel out and it will sound like **** that 1/4 inch of lip left after the key hole saw makes a huge diff. in the sound . if you dont have the re mapp or tuner the run your stock air cleaner and it will run fine.
Old Oct 27, 2006 | 11:19 PM
gbm's Avatar
gbm
Semantics. You are technically correct if you consider that an automotive-type glass pack has a baffle. I don't.
Old Oct 28, 2006 | 12:04 AM
double_d90's Avatar
double_d90
Removing baffles without replacing them KILLS performance at least the one time I made the mistake of breaking the welds and doing that, don't do it save up and just buy a good set of pipes, in the long run you will be tons happier.
Old Oct 28, 2006 | 03:02 PM
monkyman's Avatar
monkyman
Buy a set of pipes. If you drill out the baffles and run open exhaust, Johnny law will make you get it reinspected then what will you put back on? Buy some V&H, keep the stock if you ever need it.
cajun1957a
Aug 6, 2017 06:12 PM
D-BOY
2014-2024 Touring Models
Aug 11, 2015 02:26 PM
KEYBEAR
Sep 6, 2013 04:06 PM
67wizard
Exhaust System Topics
Sep 6, 2010 10:41 PM
06BlackFLHXI
May 22, 2006 08:39 PM
