Engine surging??
Old Jun 24, 2011 | 04:05 PM
  #31
Squirrel67's Avatar
Squirrel67
Remove your air cleaner filter element and look inside your throttle body with a flashlight, If you see any black gunk in there it probally just needs cleaning, sometimes too much oil in the crankcase can cause this problem as it gets sucked through the breather and into the throttle body, it makes a dirty mess. To clean the inside go to your local auto parts store and get some automotive throttle body cleaner in a spray can follow directions on the can, and when you are cleaning it clean the IAC plunger through the small hole in the inside of the top of the T/B, this gets dirty and will make the engine surge. Hope this helps.
kripto kronic
Aug 27, 2015 08:43 PM
Rickr01
Feb 1, 2012 09:43 AM
imbthree
Exhaust System Topics
May 18, 2011 08:14 AM
AustinXL
Aug 16, 2010 09:12 PM
shakak
Sep 25, 2009 03:49 AM
