Big Tire Tips?
Old May 23, 2011 | 12:23 AM
fixxr's Avatar
fixxr
Default Big Tire Tips?
Well How big can I go without a lot of work?I'm running a 160/70/17 on a 17x4.5 deuce wheel now(Metzeler880)I just got a 170/60/17(Metzeler880) You got to remember this is going on an 05 SG.The new tire should only be a little over a 1/4" wider.any one ever ran this size?Got any tips for me?
Old May 23, 2011 | 04:41 AM
HemiOrange's Avatar
HemiOrange
This won't answer your question, but will give you an ideal of how close you can run.
I went for a ride last week with a friend that recently bought a 2004 Big Dog Chopper. He had a Dunlop 250 on the rear, the same as came on the bike. He was telling me that when he first picked up the bike that he could barely slip a piece of paper between the swingarm and tire on either side. After checking tire pressure, he saw that the tire was only at 30 lbs and the specs called for 45. He inflated the tire to 45 and could now slip 4 pieces of paper on each side of the swingarm!
I had to look to believe it. There was barely any distance on either side, but he was correct, both sides were equally close, it looked to be less that 1/32nd of an inch. Talk about close tolerances and precision parts!
Big Dog is no longer with us, but somewhat close tolerances are still possible with our Harleys, but I'd feel better with at least 25 sheets or 1/8" of clearance.
Old May 23, 2011 | 05:17 AM
carltex's Avatar
carltex
I'm running a 170/60-17 Screamin Eagle on my 07 SG. Has that lip on the outside that a Metzler doesn't have so it probably looks wider. Fills up the fender up pretty well.
Old May 23, 2011 | 05:18 AM
AFMM3's Avatar
AFMM3
Here is a handy chart.............http://www.hdwheels.com/Product.htm
Old May 23, 2011 | 08:52 AM
fixxr's Avatar
fixxr
Anyone with an "05" or older try to do this size?I know it fits the 06and up SG with the bigger fenders.I'm worried about the wires and the belt rubbing.
carlgrover
EVO
Apr 17, 2019 01:21 AM
gravelmanv11
2014-2024 Touring Models
18
May 16, 2017 09:00 PM
mandd71974
Wheels/Tires
Jul 1, 2015 04:05 PM
tx-skydiver
Aug 26, 2012 09:26 AM
AzDon
Aug 4, 2007 08:50 PM
