Fatbob headlight on FXDC
Old May 23, 2011 | 02:38 PM
shrini23's Avatar
shrini23
Default Fatbob headlight on FXDC
Would a fatbob dual headlight fit my 2009 FXDC (49mm) trees
Is anyone running this setup on their FXDC?
Pls share some pics
Old May 23, 2011 | 04:37 PM
leepetersusn's Avatar
leepetersusn
Not running it on an FXDC, but running it on an FXDB. Take a look at my photo gallery.
Old May 23, 2011 | 06:37 PM
8541hog's Avatar
8541hog
Should bolt right up, and simply unplug the old and plug in the new.
Old May 27, 2011 | 08:03 AM
shrini23's Avatar
shrini23
When I see the parts catalog it says fits only 06-08 FXDWG.
This keeps me wondering if it'd fit my 09 FXDC
Old May 27, 2011 | 08:07 AM
8541hog's Avatar
8541hog
As you can see, I have 1 on my 05 FXDWG so don't believe everything you see in the catalog. I had to make a different mount because the trees are closer together on older WG's.
What is the width between your fork tubes?
Old May 27, 2011 | 09:48 AM
shrini23's Avatar
shrini23
49mm trees
Old May 27, 2011 | 09:49 AM
8541hog's Avatar
8541hog
Originally Posted by shrini23
49mm trees
Do you have narrow or mid forks? Distance between the tubes?
Old May 27, 2011 | 01:21 PM
cknight98's Avatar
cknight98
i was just thinking the other night how sexy the dual headlight would look on my Super Glide... if this is doable, i very well may do this too...
Old May 27, 2011 | 01:30 PM
8541hog's Avatar
8541hog
Having built a mount to make it work on mine, I can say with confidence, it will fit on any Dyna. You just may have to fab some kind of mount.
ambrose
Nov 26, 2015 12:25 PM
streetbob09
Mar 12, 2011 11:00 AM
AVilla
Jun 8, 2010 10:19 AM
Frog33
Mar 15, 2010 07:21 AM
smokin13
Feb 2, 2010 01:53 PM
