question about detachable sissy bar install
i just ordered a one-piece sissy bar and detachable hardware to install on my '10 fxdwg. i already have the license plate/turn signal relocation kit from greatbikegear.com installed on the bike, so what do the back anchor points on the hardware kit mount to? will i have to buy additional bolts to make this work?
thanks in advance,
G.
-When you remove the lights to reinstall them. Disconnect the connector, I am not sure if yours connector is under the fender or runs all the way under the seat. The latter would be better! Take a picture of the connector with the wires in it and write down which wire goes to which slot. Then de-pin the connector. MUD has a good video on how to do this, very easy.
-The bolt that the light screws onto is hollow and you will need to run the three wire from the light through the larger hole on the light housing (where the bolt screws into it) and then through the bolt. You will beed to cut off the connector ends because all three wire won't fit with the connectors on. You can either cut off enough wire attached to solder them back together or pick up some new pins from your dealer (maybe 50 cents) and repin the wires after they have been fully ran and the fender is installed.
-You can install the new fender support, screw in the front and back bolts (lights not installed yet) with the detach hardware and secure the fender. Make sure you have enough room under the fender to access the hole behind the seat from under the fender, you will need this to route the light wires!!!!!
-With the fender secured, installed the locking nut onto the rear bolt (tightens up against the light housing to hold lamp in place)(also make sure the new cover is installed on the light housing, you will know what I am talking about when you see it) and then pull the wires to the lights through the hole in the rear bolt and screw the light onto the bolt (you will need to twist the wires from inside the fender while doing this). Get the light to the angle you want and tighten the lock nut to the housing.
-Run the wire through the provided channel that gets attached to the support bracket inside the fender. then through the hole in behind the seat. (I picked up some foam channeling from the dealer to run the wire through to protect it and keep it against the fender.)
-Repair the wire and repin the connector, plug it in and you should be good to go.
Here is a pick of what the kit looks like installed. If you have any questions PM me, I will answer what I can.
Mike
ken b - although i used a different kit to relocate my turnsigs, i am in the same boat you were in and i just needed to know what size/length bolts you used and if they were an HD part what the part# was. thanks.
