changing fenders
Old Feb 28, 2013 | 08:44 AM
03_Nightrain's Avatar
03_Nightrain
6th Gear
Default changing fenders
I'm wanting to install a 03 heritage rear fender on a standard. Does anyone know if the bolts match up? Will I need to pull the rear wheel? What am I getting into?
Old Feb 28, 2013 | 09:28 AM
IronAss's Avatar
IronAss
Check the part 's for the fender strut covers, if they both use the same number then the bolt holes will line up.
You shouldn't need to pull the wheel, just pull the seat and the fender bolts. You might have to lengthen the wires going to your tail light though.
This is all just off the top of my head thought's I'm sure someone that is more up to speed on this will correct me if I'm wrong.
Old Feb 28, 2013 | 11:37 AM
Hogpro's Avatar
Hogpro
Former Sponsor
It should bolt right up. Not sure on the length of the wiring for the brake light but I think it will work fine without issue.
Old Feb 28, 2013 | 12:40 PM
back again's Avatar
back again
you will need to lengthen the left side light harness. They are backwards from the fx on the side they connect. Fender will bolt up. Think there is 1 more bolt hole for the light bar on the Hert. strut cover.
JTL
Apr 15, 2014 05:24 PM
Yo Nadz
Aug 3, 2012 01:19 PM
Doc G
May 26, 2011 04:41 PM
MYKSHD
Jun 6, 2009 08:51 PM
sgdiesel
May 18, 2009 08:34 AM
