Difference between FXDB and FXDC tank console
Old Jun 16, 2011 | 09:04 AM
128auto's Avatar
128auto
Default Difference between FXDB and FXDC tank console
I am thinking to put a console barrel ignition switch on my SB, beside the panel, can I reuse the speedo and idiot lights? I found a OE switch at Drag specialist, what other parts do I need?
Old Jun 16, 2011 | 09:47 AM
craigffb's Avatar
craigffb
The Street Bob had a smaller (4 1/2 in) speedo...idiot lights I belive are the same. Not sure I understand...are you swaping out the console or just cuting what you have to put in the barrel?
Old Jun 16, 2011 | 09:58 AM
128auto's Avatar
128auto
Thanks! I want to relocate my ignition switch from frame to console, I will order the switch first, if it is thin enough to hide under the stock panel, I will cut a hole and stick it in there. I still love the stock panel, hopefully I can keep it.
Old Jun 16, 2011 | 11:07 AM
craigffb's Avatar
craigffb
You should be able to keep it. Others have done it and posted the info....do a search and you should find everything you're looking for.
Old Jun 16, 2011 | 01:32 PM
stev0n's Avatar
stev0n
the street bob has a 4" speedo & smaller idiot lights.
The fxdc has a 5" speedo & larger idiot lights (i believe)
at the absolute least, you HAVE to get the new speedo.
you can use a holesaw & cut a hole in your fxdb dash for the new ignition or get the 2010/11 wide glide dash & reuse all your parts.
search for moved ignition or relocating ignition
Old Jun 16, 2011 | 01:47 PM
128auto's Avatar
128auto
I either make a hole or relocate the ignition on the left side, thanks a lot guys!
FXD_noob
Nov 3, 2015 09:10 AM
sal50
2014-2024 Touring Models
Oct 1, 2015 08:47 AM
guzzishop
Jul 15, 2014 07:14 PM
KustimKool
May 29, 2012 09:40 AM
Wonkaboy
Jan 25, 2011 05:51 AM
