Fat Bob dyno'd at 70HP???
Old Jul 5, 2011 | 08:50 PM
ackman1968's Avatar
ackman1968
Seems like reasonable numbers from what I've read. I think the guys hitting 80 or more with just pipes and air cleaner are the exception (probably relative to the difficulty of finding good dyno operators). Never had mine dyno'd but should and if I did I would expect 80/85 hp. I have Cobra Dragsters, SE A/C and Andrews 26H cams. Really want the Fat Cat though!
Old Jul 5, 2011 | 09:06 PM
WG2011's Avatar
WG2011
As I said above I am going with numbers not he said she said and I have the v&h 2 into 2 and got great numbers. Maybe mine was rare? But stage one at 85hp 99tq I thought was damn good maybe I am wrong? Read sig for exaclt parts of stage one. Not trying to start an argument but from my experience with the 2 into 2 got great results.
Originally Posted by neocontra
V&h big radius pipes are really poor as far as performance is concerned. **** poor. When I had them on my night train and swapped them out for a set of bub staggereds there was a huge improvement in performance. Both sets of pipes were mapped for as well with a sert.
Old Jul 5, 2011 | 09:41 PM
Sonic_Excess's Avatar
Sonic_Excess
I don't have any experience with the bike in this department but with my cars I found who is running the dyno makes a huge difference probably more so than the actual tune I have seen 2 different shops dyno the same car, no changes between, and come up with 2 different numbers they were close but still quite different.
That could be why the same stage one upgrade on the same motor but from bikes around the country in this thread are all pretty close but still has a good spread. After different dyno makes and weather, altitude/atmosphere adjustments and then different operators it would be impossible to get the same numbers for the same mod.
My advice take dyno numbers with a grain of salt call it a ball park figure and just enjoy the upgrade for the ride and not the numbers.
Old Jul 6, 2011 | 01:46 AM
Foxster's Avatar
Foxster
Well said. This explains the range of values that people get for more or less the same mods.
You have to be very wary of known tuners that somehow always seem to get more out of a bike than anyone else. In my experience most of these guys have their 'finger on the scale'.
I had a few dyno pulls at a local machine when I was doing my own stage-1 tuning with a SEPST. I got around 76HP. A few weeks later I was at a show and a guy there was offering dyno pulls and tuning, so for giggles I got a dyno pull by them - 81HP. They had obviously frigged their machine to read high for the show.
Its pointless to compare bikes on different dyno machines because of this. Its only really reliable to get a pull, do your own mods and tuning and get another pull on the same machine.
Old Jul 6, 2011 | 07:21 AM
Maclugie's Avatar
Maclugie
74 HP / 85 TQ. Slip ons are the best bang for the buck unless you go to a 2 into 1 pipe. My opionion, of course.
Old Jul 6, 2011 | 07:42 AM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by ironman2011
V+H intake, fuelpak, shortshots staggered exhaust. No dyno. 79HP and 90 ft lbs torque. That was on a 2009 Fat Bob.
Originally Posted by OldMike
No dyno?
Either A) Ironman is confused and doesn't know what a dyno is or B) He's a statistics major, and made those up just like 87.45% of all statistics.
Old Jul 6, 2011 | 07:54 AM
dyna rider's Avatar
dyna rider
Default Dyno
There are so many variables that affect a dyno run...First is the operator, then altitude, temperature, humidity (grains of water per square foot), if the dyno is indoors or outside....and the list goes on and on.
I can feel the performance of my bike get better in the winter (cold air is more dense) at lower altitude.
Old Jul 6, 2011 | 08:28 AM
neocontra's Avatar
neocontra
Those are great numbers and I'm not saying that good results aren't possible with big radius pipes, I'm sure they are (as you've experienced). What I'm saying is that it seems like that is not the norm. In my personal experience and what I've seen they are generally poor performing pipes compared to others out there.
It's a classic case of form over function.
Old Jul 6, 2011 | 08:53 AM
cjlandry's Avatar
cjlandry
I don't put much stock in such numbers without seeing a chart. The over-all torque curve is much more important than peak numbers. Peak numbers are pretty meaningless in the grand scheme of things.
I'd rather have a setup that can hold 80 pounds of torque across a broad range than one that peaks at 90, but has the torque coming up too late and only briefly.
Old Jul 6, 2011 | 08:54 AM
WG2011's Avatar
WG2011
Agreed on the form over function not going to lie there loved the 2 into 2 look and actually did not know they were not so good with performance after the tune however I am not disappointed in the least. I will agree that there are much better pipes for performance but then again so many variables effect everything. I will have to post up my dyno sheet torque curve was awesome blasts up right away and stays high through out obviously not the case with HP gradually increases and rpms increase.
