Wide Glide bars
Old Jul 7, 2011 | 02:36 AM
==ShaDoW=='s Avatar
==ShaDoW==
Yeah I had Z bars and risers but had to undo the bolt on the triple tree for the brake line, about 12- 14" in total I think on stock gear,
Old Jul 7, 2011 | 07:42 AM
craigffb's Avatar
craigffb
Originally Posted by BubbleGutZ
i put 14" apes with 3.5" risers and i had enough length for wires. Just had to get longer cables.
Cool. That's what I needed to know. Thanks
Old Jul 7, 2011 | 08:57 AM
WG2011's Avatar
WG2011
Yeah wires there is quite a bit of extra under there but cables not a ton of slack. So basically the OP's buddy is set with the cheap easy part but not the the more expensive (cables) part. Take your time and have fun learning.
Old Jul 7, 2011 | 10:51 PM
BubbleGutZ's Avatar
BubbleGutZ
Yeah no problem n good luck with the project.
Old Feb 9, 2016 | 02:46 PM
nick_91's Avatar
nick_91
Stage II
Default Did you gave to change anything when you swapped the risers or is it all stock
Did you change anything at all with your risers changed and also with them being internally wired is it hard to unhook them and to change the actual bar
QUOTE=pjhudson;8541265]Stock bars, but with 3" of additional riser. I could probably do another inch.
[/QUOTE]
Old Feb 11, 2016 | 01:34 PM
Repoguy's Avatar
Repoguy
I had a 11 wide glide, did 10" t-bars. Only had to move the clutch cable to the inside of the frame.
Old Feb 11, 2016 | 08:00 PM
crcraig's Avatar
crcraig
14 is the tallest he would be going....so hopefully the wires will be long enough....can some one who went with a 12-14 inch ape chime in? I plan on using OE Street Bob cables cause I know they'll fit and can be had at a decent price.
I put 10" bars on mine and had to change the brake and clutch lines out to 6" longer than stock lines. All the electrical was plenty long enough.
SPCJ
Sep 4, 2015 01:24 PM
WhiteGlide1
Apr 29, 2008 06:53 PM
dogcop727
Sep 10, 2007 04:50 PM
Critter174
Aug 22, 2007 09:24 AM
Mikind7
Mar 31, 2007 12:26 PM
