grinding/rubbing while bottoming
Old Jul 14, 2011 | 05:00 PM
bladeguy's Avatar
bladeguy
Default grinding/rubbing while bottoming
This is a tricky one. 1993 FX DWG. When I have it loaded with lots of gear and my girlfriend and we hit a bump there is a grinding/rubbing sound when we bottom out. This sounds really bad - not just a bottoming of the shock. Originially this happened when I was missing one front motor mount bolt and the other came loose. I could fix it by tightening this bolt just a tad - maybe 1/8" when it came loose. Now its back but that mount is intact. Any ideas? When I had the original repair they said my trans spline was shot. Could this have anything to do with it? Btw there does not appear to be any rubbing on the tires or drive belt.
Thanks!
Old Jul 14, 2011 | 08:28 PM
SuperFastGlide's Avatar
SuperFastGlide
not to be a smartass but, maybe you have your bike overloaded.... you shouldn't be bottoming it out....
Old Jul 14, 2011 | 08:31 PM
that_guy's Avatar
that_guy
This^^^
Old Jul 16, 2011 | 03:25 AM
HemiOrange's Avatar
HemiOrange
Your shocks are either shot, too short or you need to crank up the preload.
Old Jul 18, 2011 | 09:05 AM
bladeguy's Avatar
bladeguy
okay - poor choice of words. I do not believe the bike is bottoming. I do not believe I have a problem with my shocks. Tightening the engine mount solved the problem. Something is rubbing and its metallic sounding. I don't think my shocks are fully compressed when this happens. Bad shocks are not cured by tightening the motor mount 1/8". Thats why this is a tricky one. Sorry I used the word bottoming...
bladeguy's Avatar
bladeguy
No wear on tires - sounds like its coming from the drive train...
Hepper
Feb 26, 2014 01:33 AM
tujo33
EVO
Jul 9, 2011 05:38 AM
THE YETI
Jul 16, 2009 11:30 PM
JollyRogers
Jan 6, 2007 09:50 AM
