Touring docking hardware on a Dyna
Old Jul 25, 2011 | 01:49 AM
XjldX's Avatar
XjldX
Default Touring docking hardware on a Dyna
Hi, I have searched all over the forums and anywhere else on the web that I could think of and I can't seem to find an answer to my question...
I have the quick release docking hardware from a '98 Road Glide (sissy bar, luggage rack) and I want to get a quick release backrest on my '07 FXD. My question is this: Is there any way to use the hardware that I already have and just buy the sissy bar? Are the touring and dyna parts interchangeable or are they incompatible?
Thanks in advance for any help that you may be able to offer,
jld!
Old Jul 25, 2011 | 10:16 AM
blueangel73's Avatar
blueangel73
As fare as I know the docking plates are not interchangeable.
Old Jul 25, 2011 | 12:45 PM
LeatherPro's Avatar
LeatherPro
Former Sponsor
The rear docking point that the latch uses (has the wide black plastic section) should be the same. The front one that the fork slips into might be different. All 06 and newer Dynas use a front point that is only about 5/8" long (due to the tapored strut) the older ones used a front point that was 1" long (due to the straight strut). If your front point from your Road Glide is 1" long, you can make it work by slightly bending the sideplates, but that also makes it stick out further. You should be able to get just the front points from your parts guy, instead of having to buy the whole kit. You will have to get different sideplates.
Old Jul 26, 2011 | 03:20 AM
XjldX's Avatar
XjldX
Sounds good, I'll look into that, thanks for the help. I just figure, I got the docking parts, why let 'em go to waste if I can still use them!
KWaller
Aug 28, 2015 08:23 PM
Sandyflatlander
Aug 18, 2015 06:38 AM
TBoat
Aug 4, 2010 07:22 PM
skim1420
Jul 5, 2009 08:10 PM
rhinoWErX
Mar 11, 2008 06:55 AM
