stretch struts on dyna?
Old Aug 2, 2011 | 12:39 PM
escherWG's Avatar
escherWG
Default stretch struts on dyna?
so is it possible? I need to stretch the rear fender struts to make them just a bit wider.
has anyone done this and have a good method? will the pressure from the fender eventually squeeze them back or is there a way to hold them apart?
Old Aug 2, 2011 | 12:46 PM
JRK5892's Avatar
JRK5892
i have seen this done with a bottle jack and torches in the past. why are you trying to open them up? how wide do you need to go?
Old Aug 2, 2011 | 12:53 PM
escherWG's Avatar
escherWG
JRK, i need them about 1/4" wider. Or 1/8 on each side. The reason is because i tossed a 5.5" wheel and 200 under there and there is a small contact point (where the signals mount to the fender) that rub the outside of the radial wheel when i hit bumps.
Now JRK, i know you aren't a fan of the 200 conversion, but its looks F'n sweet and the radial is much for my style of riding, so we can agree to disagree on that point.
So ya think just put a torch on each end near where it mounts to the frame and crank it open and let it sit there for a bit until the metal has cooled? won't they just bend right back in?
Old Aug 2, 2011 | 01:36 PM
trip20's Avatar
trip20
One of the guys from the FL Dyna group had a shop cut each strut in two places towards the shock mounting point.
Each cut was part-way through the strut so the strut could be bent out. Each cut was then welded to fill in the gap, then the second cut was made, bent and filled.
I think I have that right anyway......
Hopefully whoever it was will see your post and chime in. I saved a picture of it but havin a hard time locating it. I'll keep digging.
Old Aug 2, 2011 | 02:16 PM
escherWG's Avatar
escherWG
thats not a bad idea! thanks man! now to hunt down a welder...
Old Aug 4, 2011 | 05:55 PM
JRK5892's Avatar
JRK5892
personally i would cut and reweld both struts, easiest and cleanest way to do it and make sure it is even, i dig a 200 just not a 300
Old Aug 5, 2011 | 01:10 AM
HemiOrange's Avatar
HemiOrange
As long as you are widening the struts 1/4", you might consider going with a wider 8.5" rear fender. That way the tire will be able to go full stroke without interference. My stock rear fender measured 8.25" at the struts.
CharlieJP
Aug 3, 2011 01:45 PM
bosken
Apr 6, 2009 08:59 PM
VenturaChop
Nov 19, 2007 09:30 PM
..but Ill try 2 try
Mar 24, 2006 01:34 AM
Islander
Feb 21, 2006 01:37 AM
