How do you turn off your Dyna?
Old Aug 3, 2011 | 01:54 PM
thedonthere's Avatar
thedonthere
Originally Posted by bswearingen
threads like this make my head hurt
+1 me too
Old Aug 3, 2011 | 02:13 PM
JBoggs's Avatar
JBoggs
Originally Posted by 952dave
When I park, I just leave it in gear, then dump the clutch, it might take a couple of times to get use to it.
This = funny, will try this method later.
Old Aug 3, 2011 | 02:40 PM
oldbie's Avatar
oldbie
Give it a cold shower.
Old Aug 3, 2011 | 02:50 PM
dsbfxdwg's Avatar
dsbfxdwg
The whole process is way too complicated I just get off the bike and have someone else do it
Old Aug 3, 2011 | 02:57 PM
WG2011's Avatar
WG2011
Headlights are on as well as dash lights when you turn off by handlebar switch. I have been doing this since I baught it and have yet to forget but I don't have the security so I have to lock it with the hey which reminds me to turn ignition switch cause I have to in order to lock. DO what you want it probably not going to matter much or it would be a big issue ppl talk about and its not.
Originally Posted by craig11dyna
On the 2011's you don't need to use the key if you have the key fob with security. I have been just turning the ignition to the off position and walking away. Bike won't start unless the key fob is within 2 feet. Just concerns me that the manual states to use the stop switch first. Seems dumb to me and can leed to you forgetting to turn the ignition switch off..... which equals a dead battery.
Old Aug 3, 2011 | 03:29 PM
cmancini26's Avatar
cmancini26
Dealer turns mine off by key all the time so I guess its not that bad for it
Old Aug 3, 2011 | 03:41 PM
fxd03's Avatar
fxd03
I just put it in first hold the brake,give it a little gas and let the clutch out.Its the best way and you engine will last longer.
Old Aug 3, 2011 | 03:44 PM
napurist's Avatar
napurist
Funny!!!
Old Aug 3, 2011 | 03:54 PM
Sharknose's Avatar
Sharknose
I like to ground the tip of the sparkplug to the cylinder. If it was good enough for Lawnboy in the early 60s, it's good enough for harley today.
But seriously...it's your bike, shut it off any way you want. You have our permission.
Old Aug 3, 2011 | 04:00 PM
Punchsmack's Avatar
Punchsmack
I just use the auto shutoff feature when you lay the bike on its side. My back hurts from lifting it up every time I ride it, but it's worth the hassle instead of just hitting the kill switch that's so far away from my hand placement.
Seriously.....kill switch and then key. Safer.
