exhaust gaskets with propipe?
Old Aug 17, 2011 | 10:39 PM
018245's Avatar
018245
Default exhaust gaskets with propipe?
installing a V&H HO propipe on my 2011 street bob...the ends of the header tubes are square for lack of a better word, as opposed to the stock tapered pipe. the V&H tubes are the same OD as the stock exhaust gaskets...i removed the gaskets and test fitted the V&H pipes with no gaskets and it seems to fit snug...is this pipe designed to run a gasket? if so which one? thanks
Old Aug 17, 2011 | 11:01 PM
O-Town D's Avatar
O-Town D
Resist the temptation to run the pipes without gaskets - leaks are guaranteed and the hard steel pipe torqued against the softer aluminum alloy head will probably cause damage you really don't want.
If the Pro Pipe won't seat properly with the std HD tapered exh gaskets then try the SE flat ring gaskets (#17048-98). Hope it works out for you.
Old Aug 17, 2011 | 11:06 PM
018245's Avatar
018245
ok thank you...i have to go to the dealer anyhow to get new exhaust stud nuts...
Old Aug 18, 2011 | 12:28 AM
apehanger65's Avatar
apehanger65
what he said....use gaskets
Old Aug 18, 2011 | 03:21 AM
018245's Avatar
018245
im definitely set on using gaskets....in reading up in the Touring forum, almost everyone says the SE or Cometic flat seals leak? are they thinner than the OE gaskets? because with the OE gasket the pipes sit basically outside of the cylinder....maybe 1/16' in...doesnt seem right at all
Old Aug 18, 2011 | 11:25 PM
018245's Avatar
018245
got the SE gaskets today at the stealer...surprisingly cheap. anyhow they worked great, no leaks as of yet, thanks for all the info guys...
Old Aug 19, 2011 | 12:05 AM
pontiac69's Avatar
pontiac69
I was going to say, i used the SE ones since my vance and hines have a square not tapered end. Worked perfectly.
Old Aug 19, 2011 | 02:44 PM
edgez's Avatar
edgez
6th Gear
Used SE with stock pipes. Re-torqued (when cool) after couple heat cycles, knock wood all is good!
Old Aug 19, 2011 | 03:22 PM
ynots's Avatar
ynots
Ditto on the SE gaskets, especially with a square exhaust flange. They worked great on my Bub 7, no leaks even after reusing the same gaskets once. PPL diss the SE gaskets, personally I wouldnt use them with a tapered flange.
1Cardiac
Exhaust System Topics
Aug 7, 2017 11:08 AM
d24112
Nov 27, 2016 08:31 PM
canyonking
Dec 6, 2015 09:01 PM
Egldr05
May 26, 2012 07:32 AM
HOGNIT
Jun 14, 2011 07:31 PM
