FLD Floor Boards
Old Oct 5, 2011 | 05:08 PM
  #31
Harley Tim's Avatar
Harley Tim
Hello All,
Speedhitter....No. The '12 FLD footboard L/H fwd bracket mounts in the same place as the fwd controls. (Just aft of the engine guard mounting clamps) And, works well with the "Guard" installed. I have an HD engine guard installed on my '06 FXD w/ '12 FLD footboards.
Silverado05533....The P.N. for the Brake Rod is 38161-12, price, $ 72.56, as listed on my quoted post from FXD2003Rider, post #29.
IRONIC.... I tried using the brake rod from my DH fwd controls and, it was only engauged by about 4 threads on the master cyclinder. Plus, the '12 FLD brake rod is bent differently and, a little longer so It allows for much better clearance on the fwd headpipe of my Vance & Hines Big Shots.
Sorry, No pic's yet folks. Been a busy week. I'll try real hard to get somthing going in that department this weekend.
Best wishes.... Tim
Old Oct 8, 2011 | 06:28 PM
  #32
Harley Tim's Avatar
Harley Tim
OK Folks, ....Here's som pics of my '06 FXD w/'12 FLD footboards. Not the best by far, but I'm technically challenged in that department.
http://s1203.photobucket.com/albums/bb395/Harley_Tim/
Best wishes....Tim(HT)
Old Oct 10, 2011 | 10:33 PM
  #33
Silverado5533's Avatar
Silverado5533
Default Thanks Harley Tim!
Great looking bike! And I'm a fan of the black look too.
I just grabbed your pics of the conversion for further study. I appreciate the updated parts shopping list too. It's superbly done. This is my winter project.
Old Oct 12, 2011 | 08:33 PM
  #34
mrnone's Avatar
mrnone
Cool looks damn good
nice job on the boards I agree they look like they belong there
Old Mar 9, 2012 | 02:23 PM
  #35
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's a parts break down diagram for the FLD floorboard set-up:
Old Mar 10, 2012 | 12:12 PM
  #36
blueangel73's Avatar
blueangel73
From what I have found in the new Dyna Part Catalog everything below should be all you would need to make the complete conversion to floorboards on a 06' and newer Dyna and based on the info in the book, it should fit all models.
Prices and links are from lshd1.com
(1x)--54174-12--SUPPORT ASY,LH/FRT FTBOARD-------------------------$55.00 / $55.00
(1x)--54173-12--SUPPORT,LH/RR FTBOARD----------------------------------$42.18 / $42.18
(1x)--54165-12--SUPPORT,RH/RR FTBOARD----------------------------------$42.18 / $42.18
(4x)--50674-05--BOLT, SHOULDER, GRADE 8---------------------------------$1.20 / $4.80
(1x)--54172-12--SUPPORT,RH/FRT FTBOARD---------------------------------$55.00 / $55.00
(2x)--50621-06--FOOTBOARD ASSY, OPERATOR---------------------------$51.20 / $102.40
(4x)--7354--------NUT, FLANGE LOCKING-----------------------------------------$0.80 / $3.20
(8x)--4512A------SCREW, BUTTON HEAD TORX SEMS, .375-16X1----$0.80 / $6.40
(1x)--4997--------SCREW,BTN HD/HEX---------------------------------------------$3.20 / $3.20
(1x)--38157-12--FOOT BRAKELEVER ASY-------------------------------------$88.80 / $88.80
(1x)--38160-12--CAP,FOOT BRAKELEVER-------------------------------------$8.76 / $8.76
(1x)--42416-06--PAD, BRAKE PEDAL---------------------------------------------$3.40 / $3.40
(1x)--42665-03--SHAFT, PIVOT, REAR BRAKE PEDAL--------------------$9.20 / $9.20
(1x)--38161-12--PUSHROD,RR BRAKE-------------------------------------------$58.05 / $58.05
Total Cost without shipping ----------------------------------------------------------------------$482.57
Old Mar 10, 2012 | 08:40 PM
  #37
IRONIC's Avatar
IRONIC
You may also need the shift lever depending on which your bike came with stock. I had to change mine over because the stock lever hit the trans case when shifting into 6th gear. The new lever I used is shaped like a "C" when looking at the left side of the bike, the stock lever looked like a backwards "C".
Old Mar 10, 2012 | 08:59 PM
  #38
DCLXVI's Avatar
DCLXVI
Thanks for the list. Now if only I could use my Chrome Cash at LSHD.
Old Mar 11, 2012 | 06:12 AM
  #39
cutter4292's Avatar
cutter4292
Originally Posted by MikeyFXD35
Hey Guys,
Long time since I have posted, does anyone know if the new FLD floor boards will fix an 06 Dyna? I know people have tried with the police edition but they are hard to come by.
These should fit. http://www.cycleaffectz.com/product/27-0920
Old Mar 16, 2012 | 07:58 AM
  #40
blueangel73
I hadn't thought about that, thanks for the added info. When I put the list together I looked at the shift linkage setup and it has some of the same components as my forward control setup.
