Time to step up
Old Aug 26, 2011 | 09:52 PM
jarhead45's Avatar
jarhead45
Default Time to step up
Got a set of cams from 07 Dyna Man a while back - time to put them in. Along with a few more Stage II mods.
Install Andrews 37h Cams
Install Timken Inner Cam Bearings
Install 4* Woods Advance Gear
Install Baisley Oil Pressure Spring
Install SE 1.725 Rockers “on intakes ONLY”
Install Baker High Torque Inner Primary Bearing
Install Andrews 30T Sprocket and adjust belt
I am trying to free up some $ to get a Hillside Cycle Stage II 98" setup / kit with their blended Throttle Body. With any Luck I will see 109/111 on my numbers if I go Stage III. If that happens, which it should, My 4* gear goes to my buddy's 103 Road King "so he can keep up".
Then if that wasn't enough I an getting almost 30 pieces Gloss Black Powder Coated - at least trying to. She should look real purty and run like a scalded cat when she's done. See us desert dwellers do our mods in the summer when it hits 110 - it's time to upgrade and modify.
Old Aug 26, 2011 | 09:59 PM
missedem's Avatar
missedem
Johnny Cash will always be the man in black. looking forward to seeing how your mods work out. sounds like a great set up.
Bodean46
Dec 19, 2011 07:20 AM
mphamrick
Apr 17, 2009 06:26 PM
granddad
Feb 2, 2008 08:16 PM
wrustywrench
May 17, 2007 12:35 PM
Tubz
Exhaust System Topics
19
Dec 21, 2006 08:51 PM
