Help with my Fat Cat install
Old Aug 27, 2011 | 05:51 PM
AFONE's Avatar
AFONE
Default Help with my Fat Cat install
Finally getting around to installing a Fat Cat on the Fat Bob. I pulled the stock exhaust off but now I'm trying to see how the gaskets that came with the D&D fit into the head. They barely fit into the lip of the head but won't fit over the pipe so I'm wondering if D&D sent the wrong gaskets. I bought the pipe used and then purchased the bolt kit & gaskets from D&D with a quite baffle.
and I don't see that there was a gasket inside of the head after pulling off the stock pipe.
It's be nice if I can get it done while Irene is dropping buckets of rain outside. (sorry for the big pics...)
Old Aug 27, 2011 | 05:59 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The gasket goes inside the exhasut port not around the pipe. You can see the old one all smashed up in the exhasut port in the pic.
Drew
Old Aug 27, 2011 | 06:09 PM
AFONE's Avatar
AFONE
Drew
yea, that was the first thing I tried. It the gasket fits on the lip of the port but if I do that, I can't get the pipe inside because it won't fit over the pipe.
Old Aug 27, 2011 | 06:21 PM
SteveO-ll's Avatar
SteveO-ll
Take a little screwdriver and dig the old gasket out of the head 1st. then stick the new one in the head. Then you pipe is ready to install. it will mash down when you tighten the exhaust flange nuts.
It's not supposed to fit OVER the pipe, only seal it from exhaust leaks.........
Just like Dr. V-Twin suggested.........
Old Aug 27, 2011 | 06:42 PM
WS6 Formula's Avatar
WS6 Formula
Your gasket is still in there. I didn't use the D&D gaskets, seemed like the Screamin Eagle fiber ones would conform and seal better then the metal D&D gaskets. I also modified the D&D standard baffle into a quiet baffle.
http://www.youtube.com/watch?v=4ZkY9cnCV_s
Screamin' EagleŽ Performance Exhaust Gasket Kit
The exhaust gasket is a flat-woven stainless steel design that does not compress into the exhaust port, improving flow out of the head into the exhaust header pipe.
17048-98
Fits EvolutionŽ 1340-equipped models, XL, XR models, and '99-later Twin Cam equipped models (except Trike). (pair) MSRP US $7.95
Originally Posted by WS6 Formula
Are the cores the same? I just pulled out my standard baffle and cut off the outer can, then wrapped it with fiberglass. Not as loud, and has a little deeper tone to it.
Old Aug 27, 2011 | 06:48 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I used the S/E gaskets with my fatcat too. Easy isntall with them.
Drew
Old Aug 27, 2011 | 07:29 PM
AFONE's Avatar
AFONE
Thanks fellas, I was able to dig the stock gaskets out and get the pipe on. Wow what a difference! Can't believe that D&D calls this their "quiet" baffle. This pipe kicks donkey!
PyroMedic
Oct 25, 2015 11:11 AM
Chunky Monkey
Exhaust System Topics
Feb 8, 2015 08:47 PM
TxFF636
Apr 4, 2013 01:42 PM
Loaf0927
Oct 13, 2012 12:53 PM
2003flhtci
Mar 28, 2009 08:38 PM
