Moisture Problem!
Old Nov 21, 2006 | 09:35 PM
Naz_Man's Avatar
Naz_Man
Default Moisture Problem!
As most of you may know I just built me a new building for my bike. It's built with wood and is completely air tight, with the exception of the door. The problem I'm having is: It sits in there all day without anyone opening the door while I'm at work, I come home open the door and my bike is cover with moisture. Is it because I have no ventilation? The temperatures here have been 30s-40s morning lows and 45s-55s highs mid day. I started out putting a bed sheet over it but that held in the moisture even longer. Anyone have any ideas how to stop this?
Thanks Alot
Old Nov 21, 2006 | 10:07 PM
2BKFXDL's Avatar
2BKFXDL
Default RE: Moisture Problem!
Maybe a roof vent would help.....worth a thought anyhow.
Old Nov 21, 2006 | 10:08 PM
soup48's Avatar
soup48
The bike gets cold and if you have 40% or more of humidity you will get moisture on the bike. Ask your local weather man or woman.
Old Nov 21, 2006 | 10:16 PM
HD Renegade's Avatar
HD Renegade
ORIGINAL: Naz_Man
Thanks Alot
This may not sound right, but it works. Go out and buy a coupld bags of charcole brickets, the stuff you use on a BBQ grill, lay the bags flat on the floor, and cut them open. They will absorb the water in the air.
Bob
Old Nov 21, 2006 | 10:35 PM
Naz_Man's Avatar
Naz_Man
what about a dehumidifier?
Old Nov 21, 2006 | 10:37 PM
HD Renegade
ORIGINAL: Naz_Man
My way does not use electric, nor do you have to empty the water bucket either.
Bob
Old Nov 21, 2006 | 10:41 PM
clayman's Avatar
clayman
How often do you replace the bags Renegade
Old Nov 21, 2006 | 10:55 PM
HD Renegade
ORIGINAL: clayman
The person that I learned this from store his bikes for the Winter months in a 3-place enclosed bike trailer, and uses 4 bags.
Bob
Old Nov 21, 2006 | 11:07 PM
clayman's Avatar
clayman
Cool, ill give it a shot my bikes get alot of moisture as well. Mt brother has an old shovel and his has baan in his shed for years, every winter it sits and gets lots of moisture and no problems. I think it looks worse than it really is.
Old Nov 21, 2006 | 11:11 PM
HD Renegade
ORIGINAL: clayman
I have also heard of people spraying their chrome with WD-40 for the winter then wipe it off in the spring.
Bob
