Front Turn Signal Relocation
Old Sep 26, 2011 | 02:36 PM
Rainmakr's Avatar
Rainmakr
Default Front Turn Signal Relocation
Just ordered the Parts Unlimited Turn Signal Fork Clamp-49mm for my FXDC from Dennis Kirk (Part #: 213963). Was wondering if anybody used this setup before and what they thought of it? Was it a pretty straight forward install? Need any additional parts? Thanks
Attached Thumbnails Front Turn Signal Relocation-parts-unlimited-turn-signal-fork-clamp-49mm.jpg
Old Sep 26, 2011 | 02:57 PM
karlelvis's Avatar
karlelvis
Michael -
Brackets are always a good easy way to go, and there are lots of options (most of which are cheaper and better looking than the ones from The Motor Company).
Personally, I've been looking for a really clean front signal relocation scheme for a while. I don't have a lift yet so I hesitate to try a fork wraparound that requires dis-assembling the forks (yet), otherwise I would have gone for joker's fork mount (http://www.jokermachine.com/itemstre...&Placeholder=0)
I don't like most of the relocation brackets (the brackets are clunky and they tend to only come in chrome), and I prefer turns that are as minimal as possible (bigger objects don't make the signals more visible; I *hate* the stock signals on my street bob).
I just ran across the custom dynamics 'TruWRAPZ' , though, which I think is a great solution:
http://www.customdynamics.com/trufle...D_Turn_Signals
Basically, a wrap-around-stick-on LED band that can be mounted on the forks anywhere.
What I like about these is that they're so minimalist that they don't look like turn signals at all 'til they light up.
I'm reasonably sure I'll replace these later when I get time and space to pull the front end apart, but I think the wrap solution is a great way to go (caveat, I have not installed them yet but I'll post pix as soon as I get 'em on - which will be soon because I've already pulled the stock k turns off and have wires hanging out of my ride).
Old Sep 26, 2011 | 05:06 PM
mickey01's Avatar
mickey01
Originally Posted by karlelvis
Michael -
Why would you need to dis assemble your forks to relocate your turn signals?
Old Sep 26, 2011 | 07:57 PM
karlelvis's Avatar
karlelvis
The signals i linked to above, from Joker Machine, are built into one-piece brackets that go around the forks.
I love Joker's stuff, BTW. I have quite a number of their parts on my cafe racer , and all of it's absolutely beautiful. They're not cheap but they're highly recommended all the same.
Old Sep 27, 2011 | 08:01 AM
pontiac69's Avatar
pontiac69
In the pic it looks like there is a split, like a clam shell for installation. Seems kinda dumb if you had to pull the forks apart just to install these if that is what is needed. I was thinking of this same mod. But all the ones i saw open up to install on the forks.
Old Sep 27, 2011 | 10:03 AM
128auto's Avatar
128auto
What about my mod? Click here
A much cleaner look, I don't like fork clamps.
Old Sep 27, 2011 | 12:03 PM
Rainmakr's Avatar
Rainmakr
Thanks for the information and recommendations. The relocation from dennis kirk should be here sometime this week. Not sure when Ill be able to get it installed, but ill post an update when I can and let you know how this kit worked out.
Old Sep 27, 2011 | 02:57 PM
p51bombay's Avatar
p51bombay
What you want is a set of these, no wires, no brackets and most don't even notice them if they aren't on.
http://www.youtube.com/watch?v=866f11eG0EA
Michael -
http://www.customdynamics.com/truflex_flexible_led_lighting.htm#TruWRAPZ™_LED_Tu rn_Signals
Old Sep 27, 2011 | 03:07 PM
DYJ's Avatar
DYJ
You don't have to dissasemble the intire forks, just take the front tire and fender off then loosen your triple trees and slid em down to slide you signal bracket over the top. It's pretty easy and you just need a scisor jack to get the front end up.
I personally relocated mine to a box on the extra parts shelf in the garage.
Old Sep 28, 2011 | 07:54 AM
Iskra's Avatar
Iskra
Ie used those brackets and i think they are POS!!! If you get them watch out for the screws bc if you over tighten them they will go right though the weak plastic like chrome clamps ...
I had them and took them off and got the offset mounts which mount on the screw that tightens the lower tree ... they look great and are small - check it out
