white turn signals
Old Sep 26, 2011 | 09:33 PM
neocontra's Avatar
neocontra
Default white turn signals
Does anyone know if it's illegal to have white turn signals? Thinking of putting them on my FB to use as turn signal/running lights.
Pros and Cons?
Old Sep 26, 2011 | 10:03 PM
SC-Longhair's Avatar
SC-Longhair
Best to consult your local motor vehicle laws, wherever that may be.
Old Sep 26, 2011 | 10:54 PM
neocontra's Avatar
neocontra
Tried, can't find anything for Jersey.
Old Sep 26, 2011 | 11:12 PM
HemiOrange's Avatar
HemiOrange
An in state custom bike or car shop should know if they are legal or not, just like windshield tint shops know how dark they can go.
Pretty sure that clear lenses aren't legal in my state and I think tinted lenses might not even be legal, but I run smoke tinted lenses like everyone else. With the LEDs they are certainly brighter than factory.
I just go with the color requirements for front and rear turn, brake and running lights. If they look legal when lit, then I feel I'm good and all of my lights are lit when the engine is running.
Old Sep 26, 2011 | 11:41 PM
ynots's Avatar
ynots
you might get away with it if you use yellow bulbs
Old Sep 26, 2011 | 11:44 PM
neocontra's Avatar
neocontra
ok..just to clarify..
I have yellow bulbs with smoked lenses.
I'm gonna go LED (the 48 genesis led's) in either yellow, or white led, using the smoked lenses.
Thinking the white led would look cool as they are also running lights.
Old Sep 27, 2011 | 08:02 AM
atretes1's Avatar
atretes1
2009 New Jersey Code
TITLE 39 - MOTOR VEHICLES AND TRAFFIC REGULATION
Section 39:3
39:3-50 - Color of lights, permits; cancellation or revocation of permits; fee
Share|
39:3-50 Color of lights, permits; cancellation or revocation of permits; fee.
39:3-50. All lamps and reflectors, which display a light visible from directly in front of a vehicle as authorized by this subtitle, shall exhibit lights substantially white, yellow or amber in color.
(a)The color of light emitted or reflected by exterior lamps or reflectors on a vehicle shall be as follows, except as otherwise provided in paragraphs (b), (c) and (d) of this section:
White when the lamp is a headlamp, or spot lamp, or illuminates a license plate or a destination sign; or is located on the outside limit of a side car or other attachment on a motor cycle;
Substantially white or amber when the lamp is a side-cowl or fender lamp, running-board or other courtesy lamp, front parking lamp, back-up lamp, auxiliary driving lamp; or a turn signal on or facing the front;
Substantially red or amber when the lamp is a turn signal or a stop lamp on or facing the rear;
Red when any other lamp or any reflector is on the rear or on either side at or near the rear, except as otherwise provided in paragraph (f) of section 39:3-61 for a combination marker lamp;
Amber when any other lamp or reflector is on the front or on either side other than at or near the rear.
(b)Lamps and reflectors on projecting loads shall emit or reflect light with color as provided in section 10 of this act.
(c)No person shall drive or move any vehicle or equipment upon any street or highway equipped with any device or lamp thereon capable of or displaying a light of any other color than permitted by this section, except: an authorized emergency vehicle, an authorized school bus, or a vehicle authorized by a permit issued by the chief administrator.
(d)A permit authorizing a vehicle to be equipped with a lamp capable of or displaying a flashing light, except as provided in 39:3-54 or a light of a color other than permitted by this section, visible from directly in front of said vehicle, may be issued by the director when necessary, in his discretion, for the reasonable and safe movement of traffic. The permit shall specify the type and color of such lamp and the conditions under which a person may drive or move the vehicle with said lamp displaying a light. The permit shall be valid only when the specifications and conditions contained therein are complied with. The chief administrator shall collect a $25 fee for the initial issuance and for each subsequent renewal of the permit for each vehicle for which the applicant seeks to use such a light, provided, however, that no fee shall be charged for a permit authorizing the use of a light that is red or blue. The fee set forth in this section shall not apply to a motor vehicle registered at no fee pursuant to R.S.39:3-27. The fees collected pursuant to this section shall be considered revenue of the commission and shall not be subject to the calculation of proportional revenue remitted to the commission pursuant to section 105 of P.L.2003, c.13 (C.39:2A-36).
The chief administrator may cancel or revoke a permit issued under authority of this section whenever the conditions for its issuance no longer exist or on any other reasonable grounds.
Amended 1951, c.24; 1964, c.136, s.3; 2007, c.242, s.5.
escalade6103
2018+ Softail Models
Mar 1, 2021 08:35 AM
Robotech
Apr 22, 2012 06:23 PM
paul987
May 2, 2011 05:26 AM
SUPRPIG
Dec 31, 2010 11:54 AM
LordVngr
Dec 8, 2004 01:19 PM
