Hot Exhaust
Old Sep 28, 2011 | 08:34 PM
Ben Marantan's Avatar
Ben Marantan
4th Gear
Default Hot Exhaust
I installed a new vance & hines big radius exhaust and a programer chip on my 2006 Dyna Low Rider. Its a 88 Cu with EFI, I have been running the bike for a while and had just notice the exhaust pipe right were it comes out of the head were turning orange when I rev the bike at about 2000 rpm and when I throttle down the pipe went back to the chrome color, is this normal or do I need to program something.
Old Sep 29, 2011 | 01:10 AM
Ben Marantan
4th Gear
Thank You for the info.
Old Sep 29, 2011 | 01:19 AM
CrazyK's Avatar
CrazyK
Yep, you DO need to program something. Big chance the fuel/air ratio isn't what it is supposed to be and makes your engine and exhaust become too hot. IMO don't ride it untill you fixed it, might save you some expensive repairs in the future...
Old Sep 29, 2011 | 04:08 AM
HemiOrange's Avatar
HemiOrange
I've seen a lot of glowing pipes when it's dark outside on other people's bikes. During daylight you never notice it. Also, the bikes seem to run great.
Old Sep 29, 2011 | 08:52 AM
8541hog's Avatar
8541hog
It's normal.
Old Sep 29, 2011 | 09:09 AM
PHA-Q's Avatar
PHA-Q
Your tune is off, have it looked at and Tuned correctly....
Old Sep 29, 2011 | 09:29 AM
Piratebonz's Avatar
Piratebonz
I have the same pipes, 2 into 2 and the SERT, I have seen no glow from mine, plenty of hot though. I have the 96CI aboard tho, not the 88.
Best of luck and have that AFR checked out if it keeps you up at night.
David
ColdCase's Avatar
ColdCase
A lot of bikes will glow in the dark when run hard. Usually not when cruising but they can. You can shoot an IR thermometer on it and get the temp. To be absolutely sure the AFR is not way off, you will need to stick the bike on a dyno and check the AFR across the rpm range.
Old Sep 29, 2011 | 12:10 PM
Ben Marantan
4th Gear
thanks for the info
Old Sep 30, 2011 | 07:34 AM
SC-Longhair's Avatar
SC-Longhair
First, I'm not sure where he plugged the chip in (the techie in me is quite curious).
Which brand of "chip" did you add to your bike?
blueangel73
Sep 19, 2015 10:07 PM
Fearless (old nickname)
Feb 11, 2015 07:30 AM
mapguy
Exhaust System Topics
Jan 30, 2014 10:38 AM
FXD_noob
Feb 15, 2013 04:03 PM
lowglidin
Mar 11, 2011 09:47 AM
