Brake Rotors
Old Oct 22, 2011 | 04:22 PM
Robottom's Avatar
Robottom
Default Brake Rotors
Anyone have experience with getting front brake rotors turned. This is a 2009 FXDF with drilled rotors.
Front brakes are getting a bit grabby coming to a slow stop. Have already tried cleaning the disks and pads. Also pulled the pads and scuffed slightly with light sandpaper. That seemed to help for a while but back to jerky stops again after just a few hundred miles.
The reason for the question is that I called the dealer to get a set point on price, what would they charge to turn both rotors. Their response was Harley Davidson won't turn rotors. Obviously they want to sell new $120 each, but I really don't think these are that bad, only 17K on the bike.
So, anyway, has anyone ever had their front rotors turned and how do you feel about it?
How much did it cost and did you get what you paid for or would you have gone new if you had to do it over again?
Thanks,
t
Old Oct 23, 2011 | 09:18 AM
Harley Tim's Avatar
Harley Tim
I think...I would try changing the pads first. Go to an up-grade of low dust ceramic's... They put low end pads on at the factory, I'm thinking.
You should see a good improvement..
Just my .02 Hope this helps.
Best wishes...Tim (HT)
Old Oct 23, 2011 | 10:06 AM
128auto's Avatar
128auto
Drilled rotors are not recommended for machining as far as I know, you are causing trouble. What does 'getting a bit grabby coming to a slow stop' mean? I would check the caliper sliders first, they might be seized.
Old Oct 23, 2011 | 10:21 AM
Robottom's Avatar
Robottom
When rolling to a slow stop constant pressure on the brake lever, the brakes pulse .. grab release grab release. Not apparent until speeds below 10 mph, maybe first barely noticeable at about 15 mph.
Just cleaned everything, so pretty sure the pads are free to move around in the calipers.
When I put the bike on my lift and spin the wheel it definitely has one spot in the rotation where one of the the rotors hits the pads, very slight but makes enough of a sound to know it's not exactly true. Problem is I don't have micrometer and stand to tell which one and exactly where it's hitting.
Read in some posts here that people were using cresent wrenches to tweak their rotors when they saw / felt this, not sure if I even want to consider that so was asking about turning, but have also heard not recommended for drilled rotors.
Hate to spend that much on somehting that's just on the verge.
Old Oct 23, 2011 | 10:30 AM
nathanw's Avatar
nathanw
Never heard of anyone turning rotors on a motorcycle, ever. Even if it were possible which I think it isn't, I would recommend against it as there isn't much thickness to them to begin with. Aftermarket rotors aren't that expensive and taking a silly chance with an important piece of equipment would be unwise. Like others have said, check the pads, check the pistons, if needed replace the rotors.
Old Oct 23, 2011 | 10:44 AM
Harley Tim's Avatar
Harley Tim
Might also want to check your wheel spacers... Mine, at first glance, look the same. Not so! I "dummied up" once. took me a couple days to figure it out.
Old Oct 23, 2011 | 12:10 PM
08fxdf43202's Avatar
08fxdf43202
The front calipers on the FXDF are not 'floating' calipers like the rear... there are no pins to lube.
It sounds like you may have a warped/defective rotor by the way you describe the 'grab' in one spot when you spin the front wheel.
If the bike is still under it's 2 year warranty take it into the dealer. My guess is that the warranty just expired.
If that's the case then check the rotors 'flatness' with a straight edge. Raise the front of the bike & check multiple locations...
If theres even the slightest discontinuity or any roughness/grooving in the surface of the rotor... replace it with OEM (not cheap ebay) parts.
Old Oct 23, 2011 | 12:13 PM
128auto's Avatar
128auto
Brake pulsating usually occurs at high speed braking, I can bet you anything changing the rotor will not fix the problem.
Old Oct 23, 2011 | 12:15 PM
128auto's Avatar
128auto
By the way the proper way to measure rotor runout is using a dial indicator.
Old Oct 23, 2011 | 12:24 PM
08fxdf43202
Originally Posted by Robottom
Anyone have experience with...
...Thanks,
t
Maybe not... IF, the problem was occuring at high speeds?
