Dyna Vibration Problem
Old Dec 19, 2015 | 04:57 AM
  #81
mirrmu's Avatar
mirrmu
Went out for 500kms today after shaving the mount and the results are pretty good, mirrors are very usable in 5th gear
Like doing the shim this also helps
Old Dec 19, 2015 | 07:32 AM
  #82
rjo3491's Avatar
rjo3491
Hell, I love the vibration (at red lights). The, "best" bike I ever owned was an FJR, but I sold it in just over a year of ownership due to excessive boredom. A little chaos is a good thing!
Old Dec 19, 2015 | 01:58 PM
  #83
newdyna's Avatar
newdyna
I have had about 8-10 harleys and a buell with the 1200 over the years. I was ok with the honda vtx, but thought, maybe another HD, so I found this 08 dyna. Vibrated my feet off the pegs. Not good for an old guy with bad foot nerves, so I installed the HD foot board kit. Much more gooderer. So, as I posted elsewhere, I was feeling a lot of vibes from my suspension....mostly from the front. So, I have changed front fork oil to thinner. What I removed (factory) was about 15wt. Put in 10wt with a bit of 7wt added to thin that. Much better again. I now am happy with the feet, and the front end. Over the really rough back roads, the rear springs can be felt a bit too stiff...banging over the bumps. I may try better rear shocks. But, my bike has a great motor, and after all, this is what the harley is all about, the motor. Lots of vibes at idle and low speeds. At about 3 grand...no tach, but in 5th at about 60mph, this beast smooths out and just pulls like a freight train, as it should. Vibes are at lower revs, which is most of the time for me. BUT, with the new boards, my feet are good, and I am good. I have looked at the mounts, which have not lost their cool yet at 10k miles. Look at the lower gap....the new ones are about 1/8 inch, bad ones are over 1/2 inch.....I think OK is in the 3/8 inch range...not cracked and stretched. So, I will continue to push this beast down the back roads like a mad man, and enjoy the soft and smooth main roads for now.
Old Dec 19, 2015 | 02:36 PM
  #84
Warp Factor's Avatar
Warp Factor
Originally Posted by nick@nite
did you do it yourself? or dealer
Did it myself. My scoot was way out of warranty, and dealers seem to be largely oblivious to common problems and fixes on our motorscooters. Their first line of action seems to be denying that there is a problem. At least when a bike is still under warranty.
Things can get different when there is the potential to make money off it.
I put a couple of bikes in winter storage at a local dealer about a week ago. Yesterday, I get a call from someone in service, mentioning that several oil leaks were found upon inspection (one or more on each bike), and offering to fix these for around 800 bucks. I've never noticed or had a problem with any oil leaks, and neither bike has ever dropped one single drop of oil on the floor.
Geez, Harley, start to get a clue. Not all of your customers are idiots!
Getting back to the common and well-known front motor mount problem:
Another thing that can be done to increase this clearance is to loosen the front engine mounting bolts, jack the engine up, and re-tighten the the engine mounting bolts.
Old Dec 26, 2015 | 07:54 PM
  #85
Huggerbugger's Avatar
Huggerbugger
Originally Posted by Z
Harleys vibrate.
But how much is normal?
Old Dec 26, 2015 | 10:11 PM
  #86
Super08's Avatar
Super08
About that much, any more and you may have a problem.
Old Dec 26, 2015 | 10:13 PM
  #87
Huggerbugger
Having owned about a dozen Harleys, I know when it's not normal. I suspect a bad main bearing. Took it to the dealer and dropped it off. We'll see.
Old Jun 5, 2021 | 11:52 PM
  #88
HDkazHD's Avatar
HDkazHD
Default Motor mount still the same?
It’s 2021 now, is anyone still shimming and/or shaving their front motor mounts?
is the current motor mount still the same as before?
Old Jun 6, 2021 | 11:50 AM
  #89
Huggerbugger
Nope. Sold the Harley and bought a Moto Guzzi Calif 1400. Zero engine feel due to elastic mount.
Old Jun 6, 2021 | 12:31 PM
  #90
John CC's Avatar
John CC
Since the front mount is on an angle, as it collapses it pushes the engine towards the back. shimming the front mount just compensates for the fact that the whole thing needs to come back forward. Replacing both mounts is the only way to correct it. Consider an improved, aftermarket front mount. I'm using the Predator myself, but there are others.
