Installing Air Cleaner - Wire location?
Old Nov 6, 2011 | 09:59 AM
jupiter2's Avatar
jupiter2
Default Installing Air Cleaner - Wire location?
I am installing a Hi-Five Mach 2 (all black) on my 2010 Dyna Wide Glide. There is a 2 conductor cable that comes down off of the left side of the Throttle body with a cap on the end over the plug - not connected to anything. This slides on a mounting groove on the back lower area on the stock air cleaner backing plate. It doesn't seem to interact with the stock air cleaner except to be mounted there. It is not mentioned in the instructions for the Mach 5. I am assuming I just can wire tie this out of the way? I wanted to check before doing that just in case it has to be mounted somewhere in particular, but it looks like it is not in use.
Old Nov 6, 2011 | 10:21 AM
128auto's Avatar
128auto
Zip tie them, you should be fine. Don't ask me what they are
Old Nov 6, 2011 | 11:04 AM
bobnehoc's Avatar
bobnehoc
+1 Just zip tie it out of the way. You do not need to worry about this connection.
Old Nov 6, 2011 | 11:25 AM
Airborne350G's Avatar
Airborne350G
It is for the air cleaner on HDI models. Wire tie it up out of the way.
Old Nov 6, 2011 | 11:52 AM
jupiter2's Avatar
jupiter2
Great - will do. Thanks for the help!
Jmbeebe0722
Aug 17, 2013 03:37 PM
edgrabel
Aug 12, 2012 07:24 PM
Nytro B
Jun 7, 2009 03:06 PM
tazmandevil
Feb 25, 2008 05:25 PM
Garemlin
Aug 8, 2007 01:42 PM
