Triple tree ?'s
Old Nov 13, 2011 | 01:19 PM
SodFather's Avatar
SodFather
Default Triple tree ?'s
Im wanting to change out the top clamp on my SB. Ive found several options to choose from but then I saw these...
http://www.harley-davidson.com/gma/g...bmLocale=en_US
I was already planning on having the tree's powder coated black when I picked up the new top clamp. But I didnt see these listed for the SB. Any idea's if these will work?
Old Nov 13, 2011 | 03:01 PM
p51bombay's Avatar
p51bombay
those will work if you want to convert to WG width trees, otherwise just get an aftermarket top clamp and get it coated black.
Old Nov 13, 2011 | 03:02 PM
p51bombay's Avatar
p51bombay
Old Nov 13, 2011 | 03:29 PM
nkauf21's Avatar
nkauf21
Like was already said, Fat Bob trees are wide glide width. I am planning on doing the swap to mine sometime this winter, already have the parts. To make them work you need some spacers to make the mid glide wheel work with the wide glide width of the trees and a wide glide axle. I bought a conversion kit from Hawg Halters that came with a new axles and the spacers for the rotor and wider wheels spacers. The kit also came with spacers for the fender but I'm using a Wide Glide fender so I won't need them.
If you don't want to do the conversion then you'll need to find a top tree from a Superglide and have them powdercoated.
Old Nov 13, 2011 | 03:30 PM
nkauf21's Avatar
nkauf21
double post
Old Nov 13, 2011 | 03:45 PM
Stag556's Avatar
Stag556
Th stock Superglide top triple tree is a direct fit onto a street bob?
Old Nov 13, 2011 | 03:58 PM
nkauf21's Avatar
nkauf21
As long as it's an '06 or later top tree.
Old Nov 13, 2011 | 04:04 PM
Stag556's Avatar
Stag556
Ok, Thanks. I have a '12 and wanted to replace the top tree plus have the trees powdered black.
Old Nov 13, 2011 | 06:18 PM
8541hog's Avatar
8541hog
Any 49mm top tree except Fat Bob or Wide Glide will bolt right on. They are all the same as far as fit.
Old Nov 13, 2011 | 08:06 PM
streetbobkid's Avatar
streetbobkid
Loner industries makes one now, I believe
nkauf21
Sep 8, 2011 04:40 PM
06redneck
Aug 25, 2011 09:49 PM
toastman
Dec 4, 2010 05:55 PM
blueangel73
Oct 29, 2010 10:04 AM
streetbobber73
Mar 3, 2010 03:09 AM
