Hiccup
Old Nov 21, 2011 | 06:08 PM
stbobshadow's Avatar
stbobshadow
Default Hiccup
My 06 st bob still has the hiccup sometimes when I accelerate not all the time every once and awhile. I've changed the hose in the tank and checked the injector wires and all the grounds and can find nothing also I've checked the fuel PAC settings and still have the hiccup and suggestions.The hiccup is it cuts out when I accelerate
Old Nov 21, 2011 | 06:15 PM
stilup's Avatar
stilup
Do you have a gas filter in your tank?
Old Nov 21, 2011 | 06:50 PM
stbobshadow
Yes there is a gas filter in the tank.
Old Nov 21, 2011 | 09:11 PM
nevil's Avatar
nevil
So, did you check the filter when you changed the line?
Old Nov 21, 2011 | 09:34 PM
stbobshadow
It looked ok but not sure how to check it out.
Old Nov 22, 2011 | 05:14 AM
stilup's Avatar
stilup
https://www.hdforums.com/forum/3865035-post4.html
Old Nov 22, 2011 | 06:30 AM
dyna rider's Avatar
dyna rider
Default Hiccup
Change the fuel filter just to be safe...If you are rolling on the throttle from less than 2000rpm or less, that is your problem. Kind of like flooring your car from idle...takes a couple of seconds to cough and spool up.
My bike doesn't like to be throttled up from less than 3000rpm but pulls strong to 6500.
To check it out, ride at your usual speed in the same gear that makes it hiccup...roll on the throttle and see if it sputters...then ride at the same speed in the same gear but before you roll on the throttle drop down one gear.
Old Nov 22, 2011 | 11:12 AM
stbobshadow
Thx for the info
Jammie Robinson
Sep 29, 2017 06:27 PM
t34418l3-1
Aug 14, 2012 06:52 PM
hutchjh828
May 4, 2012 01:06 PM
Hoggin
Exhaust System Topics
Mar 29, 2007 12:11 AM
vernh59
Jan 11, 2006 03:39 PM
