Help needed ASAP
Old Nov 22, 2011 | 12:05 PM
Garyk's Avatar
Garyk
I have a couple of ramps made from 2x10 yellow pine with steel lips on one end to rest on whatever you are going up..Have used them for dynas, dressers etc never had a problem...even up into my truck....don't forget, the weight of the bike is distributed over the length of the bike, not in one spot.
Old Nov 22, 2011 | 12:22 PM
jupiter2's Avatar
jupiter2
Just remember if you are riding it in while seated on the bike, make sure the ramp is wide enough to place your feet. If you need to stop halfway up, and can't put your feet down, you could end up on your side in the lawn.
(yes, I learned this the hard way about 10 years ago. It confirmed my suspicion that I am not too bright)
Old Nov 22, 2011 | 12:37 PM
LarryLives's Avatar
LarryLives
Use a car ramp and drive that thing in there.
Old Nov 22, 2011 | 02:55 PM
Ganooch's Avatar
Ganooch
Pop the front wheel in the air and wheelie it in.
Old Nov 22, 2011 | 03:23 PM
Bo_Jangles's Avatar
Bo_Jangles
6"? If the bike Isn't slammed ride it in. Or just get a board to use as a ramp. Don't see the big deal here?
Old Nov 22, 2011 | 03:44 PM
wyldspirit's Avatar
wyldspirit
I went to lowes and found a 2 peice motorcycle ramp. less than a 100 bucks. Not too bad and worked like a charm
Old Nov 22, 2011 | 03:46 PM
FBinSoCal's Avatar
FBinSoCal
Default easy fix
Originally Posted by wyldspirit
I have a huge problem and thought I would turn to everyone here to get a quick solution. Here is the problem... I pick the bike up today and the only real place I have to store it is my shed... Building a new shop starting next week and I be dammed if I will leave the bike out in the weather. So I have the clearance to get the bike in the shed but I need a way to get it in there. I was planning on the ramps they sell at Lowes or Home Depot but after reading the reviews I don't really trust them. I was also looking at using plank 2x10x8 lumber but what would be the weight rating be on those? Like I said this is just temporary.
John, just buy 3 common bricks and lay 2 of them flat and parallel to the opening, @ the opening. Place the third one on top of those right at the opening, done deal and just drive it right up or wheel it right down. Another way, use that 2x10 and put the bricks underneath it, 2 @ the opening, one midspan. No biggie as you are only 6" up, right?
Old Nov 22, 2011 | 03:47 PM
FBinSoCal's Avatar
FBinSoCal
LOL, i like your style, low
Old Mar 5, 2022 | 06:31 PM
Darkk Helmet's Avatar
Darkk Helmet
For all those dissing me about ABS brakes, I never said I would rely on them, only that the bike was equipped with them. I even stated in the 'joke' that I would not rely on them for safe stops.
Old Mar 5, 2022 | 07:45 PM
CoolBreeze3646's Avatar
CoolBreeze3646
