sand or no sand????
Old Nov 30, 2011 | 09:18 AM
justglidin's Avatar
justglidin
Default sand or no sand????
im looking to use VHT high heat wrinkle paint on my primary cover, i have a 2010 FXD with the gray finished motor. my question is do i have to sand the cover before i prime and paint it because it has the rough texture on it already? or do i just clean it real good, prime & shot? thanks guys
Old Nov 30, 2011 | 09:42 AM
blackbear's Avatar
blackbear
I would scuff it up with a red scotch brite pad.
Old Nov 30, 2011 | 10:43 AM
justglidin's Avatar
justglidin
thanks blackbear!!!
Old Nov 30, 2011 | 12:55 PM
Scuba10jdl's Avatar
Scuba10jdl
Paint is all about the prep. work. You will be much happier with the results if you dry/wet sand of some sort before you prime and paint. It will adhere and look better and last longer. Also, keep it as clean as humanly possible for best results.
Old Nov 30, 2011 | 01:18 PM
justglidin's Avatar
justglidin
thanks scuba i will. i just didnt know if the raw HD gray cover had to be sanded or just cleaned.
Old Nov 30, 2011 | 06:26 PM
PoCoBob's Avatar
PoCoBob
I used it on my battery cover and electrical cover, I just used a scotch brite pad to scuff it up. I didn't like how it turned out so I did a second coat right over the first one and it came out really nice.
Old Nov 30, 2011 | 07:14 PM
art0565's Avatar
art0565
If you don't want to mess with scuffing, clean whole area to be painted with M.E.K (methyl ethyl ketone) you can pick it up at Home Depot or Lowes, use gloves when using it, this stuff will take off any and all dirt, grease etc. i painted the engine on my old bagger, i used M.E.K to clean the engine than painted it, it came out great, the paint held up really good, i sold it 7 years later and it still looked good.
Old Nov 30, 2011 | 08:01 PM
Newharleylover's Avatar
Newharleylover
I agree with art. MEK is quite agressive. It's awesome for removing contaminants.
Old Dec 1, 2011 | 11:52 AM
JRK5892's Avatar
JRK5892
i would not use high heat... it needs to reach operation temp to final cure you primary will not get near the 500 it needs to hit. reg paint man.. or powder of course
Old Dec 1, 2011 | 01:30 PM
Harley Tim's Avatar
Harley Tim
+1 on the M.E.K. and precautions. Also might want to think about a self-etching epoxy/polimide primer. (Good Stuff)
Best wishes....Tim(HT)
