Brake Light switch Tech and Brake Bleeding Tech for dummies (pic heavy)
2. buy a new brake light switch. I thought it would be like the front one and five bucks. Nope 22.99
3. un-thread old switch from brake tee. (standard thread I think it was 9/16 or 3/8 so lefty loosey) Guess what? Now there is air in your brake line which you will have to bleed out
4. Next unbolt the inspection cap from the rear mastercylinder. Remove
5. put the new switch in (righty tighty) I don't put any treatment on the threads right away unless it leaks then you could use some locktighte
6. loosen the bleeder bolt on the rear caliper.
7. I use some polyurithane line from ace to put on the bleeder bolt so air won't get back in the line when you pump
8. Take the end of the hose and put it in a bowl of water submerged
9. Pump the brake so all the air is out of the system. Your brake resovoir will loose some fluid and be lower level than before
10. Tighten the bleeder screw back up
11. Add dot 4 for 06-later dyna (very important don't screw up brake fluid types or guess what....your bake system will take a **** and you have to buy everything new....everything) Fill it up to where it was before or higher
12. after it is back to the level put the cover back on the mastercylinder and tighten to spec 8 ft lbs
13. put you cover back on the bleeder screw and test the brake sytsem by hand. If it feels lie it will work you did it right.
14. Test ride the bike.
15. wipe everything clean
16. Clean up and throw away the beer bottle that is now empty cause you drank it all while you were working.
oh yeah kinda on a side note don't drop you dam iphone in the bowl of water like I did
Last edited by misfitJason; Dec 20, 2011 at 05:31 PM. Reason: pics didn't show up wrong code on my part
