oil and oil filter
Old Jan 1, 2012 | 05:07 PM
  #31
Texasbrons's Avatar
Texasbrons
I am curious as to why so many people are using the same oil in all three holes. My service manual calls for the same in the trans and the primary, which would be way heavier oil than the engine. Thought?
Old Jan 1, 2012 | 10:14 PM
  #32
JimmieJack's Avatar
JimmieJack
I've been using Redline - they have a seperate blend for each hole. It's a little more expensive and I'm not sure if I'm gaining that much benefit - thinking of switching to Mobil 1 V-twin. Also, use HD chrome filter.
Jimbo
Old Jan 1, 2012 | 11:35 PM
  #33
Austin Dave's Avatar
Austin Dave
Lube specs must have changed in years after my '03. There are many 'Cautions' in one of my '03 manuals about not using engine oil in trans or primary. I use M1 V-Twin 20w-50 in the engine, Spectro 75w140 in my 5-sp trans, Formula + in the primary and HD oil filter.
Old Jan 2, 2012 | 10:10 AM
  #34
baust55's Avatar
baust55
Mobile-1 V-Twin 20w50 in crank case
Mobile-1 V-Twin T10w40 for wet clutchs in primery
Mobile-1 75w140 gear lube in tranny
used to use the K&N 171b oil filtor
i know have the FLO SS filtor
Old Jan 2, 2012 | 10:56 AM
  #35
RZA's Avatar
RZA
When changing the oil from a sportser do you drain the crankcase as well or just from the oil reservoir?
ryda
Apr 9, 2013 08:27 PM
bikerlaw
Jul 20, 2012 11:35 AM
hdxbones
May 26, 2008 08:01 PM
Yambo
Jul 26, 2007 05:22 PM
OneBlackFly
Oil Archive (no new posts)
Feb 6, 2007 02:22 AM
