Help with rockers
Old Dec 24, 2011 | 05:24 AM
LINZ FDXF's Avatar
LINZ FDXF
6th Gear
Default Help with rockers
I have an '09 fatbob on which I am installing a stg II 103" big bore kit w/ 255 cams. I am just looking for a little help so I don't screw up anything.
I am reinstalling the rockers. I have the piston at TDC. When I took it apart the rockers sat flat on the rocker box with bolts out and the piston at TDC. Now when putting it back together they do not.
I am thinking that with the stock cams both valves were closed at TDC and w/the 255's both valves will be partially open at TDC, due to the overlap at this point. Is this correct?
If so, do I just evenly tighten the bolts down while the rockers push the valves open?
Thanks for your time.
Linz
Old Dec 24, 2011 | 05:34 AM
Stiggy's Avatar
Stiggy
Yes, regardless of the cam change your lifters also expanded when the pressure on them was released. They'll bleed back down when you install the rockers after a few minutes.
Old Dec 26, 2011 | 02:48 AM
LINZ FDXF's Avatar
LINZ FDXF
6th Gear
Thanks alot.
Old Dec 26, 2011 | 04:12 AM
Foxster's Avatar
Foxster
Just stick the bike in a high gear and rotate the back wheel until the pushrods are at their lowest again.
Don't forget to get it back into neutral before trying to start it afterwards though!
Old Dec 26, 2011 | 05:48 AM
DCLXVI's Avatar
DCLXVI
It's your lifters. Follow the procedure to bleed them down and you will be fine.
Cory Heath
Engine Mechanical Topics
Jan 3, 2017 01:53 PM
magnum629c
Mar 30, 2014 10:50 PM
bagdaddy09
Feb 23, 2013 08:19 AM
Seener84
Feb 14, 2012 12:30 PM
jake40ma
Nov 6, 2010 08:54 PM
