You rarely get two people to agree on this topic because no two person's needs from a bike are the same. Here are some of the types that mess with their bikes:
1. Someone who wants a lot of noise plus shiny different pipes and a new air cleaner cover. Willing to spend $500-1000 to achieve this and don't know or care that the bike now runs worse.
2. Someone who just wants the bike to run a bit cooler and smoother. Happy to fit some Xieds and call it good.
3. Someone that wants the bike to have some more power, generally run better and not over-heat. Researches what pipes work well and finds a good A/C, then gets the fuel sorted with a tuner like a PCV, SEPST, etc.
4. Someone wringing the most out their bike at a known risk of reduced engine life and MPG. Fits the best 2-1 race exhaust, high flow A/C, big CC pistons, head work, cams, etc.
5. Lots of shades of grey between and outside all the above.
I've enjoyed your and all the other posters comments on this thread.
I fall into your catagory #3 above, I think.
That's just about what I want and here's what I'm about to do:
Full bassani system next week and will do just the K&N filter with stock cover, power commander V, and then have it tuned.
I found it real interesting you identified what I was looking for AND accomplishable by what I was going to do to get it. Bassani staff told me the exact same thing.
At this point I don't know what to do. After reading most of the threads. Already spent enough money for the winter on powder and paint.
I'm going to leave the motor alone for now. cheaper that way. It isn't like I can ride it now anyway.
a lot of very knowledgeable guys talk about the dangers of not adding a tuner/download, etc. when you change pipes and air cleaners but i have yet to see anyone post the bad results of not adding a tuner. anyone know of a thread that covers this? from what i have learned so far it seems that the ecu can't adjust the a/f mixture enough to compensate for the changes. i'm sure someone can post the EXACT limits that are set up in the factory ecu's can't they? i have seen ads and videos of companies that sell tuners explaining why you need their product for your bike.
i guess my big question is : what are the limits of the factory ecu's and why are they so narrow?
I go to two long time Indy shops. Both guys tell me that the down loads are set up for the way most people ride. These guys sing their praises of how dependable running the download is over the tunners. Both showed me boxes of toasted tunners that went bad. Seem like most were the V&H Power Comander type. Their opinion was most tunners are not dependable. Both guys ride stage 1 bikes themselves if anybody is wondering.
The only tunner both endorsed is TTS Master-Tune. Said its the way to go if your planning going into the motor with future mods. But on a stage one motor it isn't worth spending that amount of money on.
The three closest dealers to me won't even sell you the download for newer bikes (2008+) now because the download is known to be useless. One of these dealers explained clearly that they don't consider it a part of a stage-1 solution because its still designed to meet all EPA standards and not tuned for any performance upgrade. All it does is raise the rev limiter a little. When dealers won't even sell you a MoCo product you know there's something wrong with it.
As for "Their opinion was most tunners are not dependable"...both the SEPST and TTS leave nothing on the bike to go wrong, so they won't have been in the box of broken tuners.
Personally I don't think there's much to choose between the TTS and SEPST in terms of results. Though the TTS has better documentation and a nicer interface. Downside of the TTS being that if you want a shop to do you a tune you'll find fewer places familiar with it.
As for the effects of running a bike with stage-1 hardware and no tuner...Here's dyno of a 2010 Dyna with SE slip-ons and SE A/C and no tuner, produced in September:
General target AFR is the red dotted line. You can see that up to about 4000rpm the AFR is held by the ECU to stoic and below. But above 4000rpm (when into open loop mode and the O2 sensors are no longer in use) the increased flow means that the AFR has gone very lean. Run like that for a while and you'll ruin your engine, never mind all the performance you are losing out on.
thanks for the dyno post foxster. I know the facts and basically the whys but its really nice to see someone back up the why with something we can all see and is simple to understand. Interesting post OP and thanks all for the opinions expressed.
One poster talks about the smoothness of the stock efi. I too noticed how smooth the bike ran stock but in all fairness the motor mounts are brand spanking new etc. The good news is this is still the smoothest running bike Ive ever had . (7 carbed bikes before), even with the new tuner. Ran flawless from 7000 ft. down to sea level and back. That part of EFI I really enjoy. I miss the mechanical-ness of the older bikes.
Reason: decided to be gabby
Some posters have said not to use the SERT. Can anyone provide a valid reason why? Is it just that some others give even better performance as opposed to reliability or other reasons?
Perhaps it is that the SERT (or whatever they call the latest HD tuner) has a tendency to override AFR tables set by the individual doing the tune, which annoys them. The casual tuner wouldn’t notice that the settings were overridden. There are work surrounds, however, but many pros just don’t trust the HD tuner (who knows what else is modified). The similar TTS tuning kit provides more tools (e.g. cam adjustments) and does not override settings. A competent tuner can get very good results using either tool, but most prefer the TTS kit as they can tune a bike a little quicker and more straightforward, as well as have a highly capable tool for the esoteric or problem bikes.
There are several tuning products that provide excellent results in the right hands and some posters have their preferences…. some may be fan boys… some may be working for one vendor or another... some believe everything they read in the marketing literature.
We are now in year 6 of these so called factory lean bikes. I've been coming here for all that time and have never seen a single post from someone who had an engine failure due to the factory tune.
