Tuner or not...
Old Jan 3, 2012 | 01:30 PM
mjrobinson's Avatar
mjrobinson
Default Tuner or not...
Running slip ons with stage one and HD Remap on 2007 FXDB. Going to full system. Anyone run Full System without a tuner? How's it run?
Old Jan 3, 2012 | 01:52 PM
hellbob37's Avatar
hellbob37
Can almost promise you no one with a full system and an a/c is running without some sort of tuner.
Old Jan 3, 2012 | 04:14 PM
jamman's Avatar
jamman
he said he had a stage one remap..
Old Jan 3, 2012 | 04:49 PM
yso191's Avatar
yso191
What do you mean by "Full System?"
Steve
Old Jan 3, 2012 | 06:47 PM
mjrobinson's Avatar
mjrobinson
Full system as in headers and muffler. A 2:1 actually. I had stock head pipes and slip ons before. Yes, I had remap done when I got stage 1 installed. I think that may be enough. No mods to engine itself, all stock.
Old Jan 3, 2012 | 07:14 PM
yso191's Avatar
yso191
Ah. Your download will protect your motor from going too lean with the exhaust you are looking at. It is however the worst of your options, IMHO. There are several good tuners that I'd recommend, but I went with the TTS Mastertune. The best thing you can do is get your bike dyno-tuned after the pipe swap, just be sure you do your research on a good dyno operator before you do, as there are WAY too many awful ones. I don't know if they just don't care or don't get the process, but it is stunning to me how incompetent most dyno operators are.
Steve
Old Jan 3, 2012 | 07:41 PM
mjrobinson's Avatar
mjrobinson
Thanks, I am resistant to ask the dealer . All they will say is that I need to get their SERT. I understand that the remap is not the best option. Just want to know that it will run ok at least until I can decide on a tuner.
Old Jan 3, 2012 | 07:43 PM
JaronB's Avatar
JaronB
We have O2 sensors on the bikes now to automatically adjust the a/f mixture to the stock AFR otherwise what good are they?? You will be fine without a tuner and the bike will just adjust itself to the stock a/f ratio. Now on old carb'd bikes if you didn't re-jet the bike you would run lean and screw up your motor, but with today's technology you don't have to worry about that till you start modding the motor internals. Tuner will maximize performance of the add ons and tuners trick the bikes computer and running what is programmed (dyno or map), which includes changing the AFR (hence running cooler vs. the stock emissions lean setting), and some other things. Most tuners get rid of the O2 sensors unless you have the auto tune which makes the bike adjust more efficiently to what your tuner is set for.
Old Jan 3, 2012 | 07:49 PM
mjrobinson's Avatar
mjrobinson
Thats what I was thinking JaronB. Actually was told that the remap was a waste of money due to closed loop FI.
Old Jan 3, 2012 | 11:39 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
The remap is not a waste of time, it does modify the VE and timing for a specific combination of HD parts and will work for similar aftermarket parts.
However that being said, the download is designed to keep your bike within emission standards. A tuner will allow you to get more performance by increaseing fuel usage at the expense of milage and emission standards.
