Help with Boom audio on street bob.
Old Jan 12, 2012 | 05:45 PM
Clint N's Avatar
Clint N
6th Gear
Default Help with Boom audio on street bob.
Hey all out there new meber to your forum. I just bought the boom audio for the handle bars for my 07 street bob mounting and wire hiding is no problem but power hook up is. If any one has done this or somthing similer i could use some advice thanks.
Old Jan 12, 2012 | 06:11 PM
fxdc rider's Avatar
fxdc rider
i tapped into the ignition switch under the tank console. plenty of room to hide the fuse under there too
Old Jan 12, 2012 | 06:22 PM
128auto's Avatar
128auto
I would run a relay, you never know how much current that audio system draws.
Clint N's Avatar
Clint N
6th Gear
did you do it on a street bob? my ignition is on the side not the tank.
Old Jan 12, 2012 | 06:23 PM
Clint N's Avatar
Clint N
6th Gear
thats a good point 128
Old Jan 12, 2012 | 06:54 PM
128auto's Avatar
128auto
You don't have to run tap the wire right at the ignition switch, try to find a key on power near the fuse box and wire a relay, that should do.
Old Jan 12, 2012 | 06:57 PM
Chicago Ken's Avatar
Chicago Ken
I would try to put the fuse under the seat. Easier to get to than under the tank.
Old Jan 12, 2012 | 07:16 PM
Clint N's Avatar
Clint N
6th Gear
ok so ive mounted the amp and the speakers now i need to conect the wires theres only 3 red black and orange with a wite stripe the instructions it came with are so damn vaige.
Old Jan 12, 2012 | 07:29 PM
ryguy84's Avatar
ryguy84
Would love to see some pics when your done and a review of the system. Good luck.
Old Jan 12, 2012 | 07:32 PM
Robtarra39's Avatar
Robtarra39
I bought the same Boom, waiting until spring to install, will be following this post, looking forward to the review.
