Wide Tire
Old Jan 30, 2012 | 10:11 PM
DynaGuy77's Avatar
DynaGuy77
Default Wide Tire
What is the widest rear tire I can put on my 2011 wide glide without any mods? Right now it has a 180. Thanks
Old Jan 30, 2012 | 11:23 PM
onemyndseye's Avatar
onemyndseye
I think 180 is your max... going to a 200 usually involves a wheel and pulley change on most bikes
Old Jan 30, 2012 | 11:26 PM
gartec81's Avatar
gartec81
180 on 17x4.5---- street bob rear rim
200 on 16x5 ------fat bob rear rim on your bike
Old Jan 30, 2012 | 11:45 PM
Doug Bromley's Avatar
Doug Bromley
I have a 200 on my 2010 WG no mods.
Old Jan 31, 2012 | 12:00 AM
gartec81's Avatar
gartec81
whats your tire size 200 55 17? didnt know you could fit a 200 on a 4.5 rim
Old Jan 31, 2012 | 12:07 AM
onemyndseye
/me either
Old Jan 31, 2012 | 12:14 AM
dustin86's Avatar
dustin86
I believe u can get a 5 and a half with no mods. I could be wrong but I thought that's what one of the guys put on there 10 WG.
Old Jan 31, 2012 | 12:15 AM
gartec81's Avatar
gartec81
2010 wg comes stock with 17x4.5
Old Jan 31, 2012 | 06:27 AM
Roadrider18's Avatar
Roadrider18
Pretty sure most of the major tire manufacturers (ie., Metzeler, Avon) recommend a 6.0" (minimum) wide rim for a 200 tire; 5.5" for a 180 (unless you go with the HD Dunlop wide tire kit which has a narrower bead width as spec'd by HD for use on 4.5" rims).
Lots of good info out there...
Here is the HDWheels.com fitament chart.
http://www.hdwheels.com/Product.htm
I believe most Dynas can accept a 5.5" rim without mods. However, a 6" rim (wheel assembly) is going to require a different spacer in order to re-establish the proper offset.
Old Jan 31, 2012 | 01:43 PM
Skatz5000's Avatar
Skatz5000
You could do a 17x6 crossbones wheel with a 200 tire and a new spacer with out too much trouble been done here https://www.hdforums.com/forum/dyna-...treet-bob.html
You can do 200 on an 18x5.5 I think metzelers me880 will feel that wheel size. As for spacers or anything or stock fender clearance not entirely sure. Just cut the fender and struts off problem solved lol
SkullsAndChrome
May 3, 2022 06:24 AM
Rrrandog
Wheels/Tires
Apr 18, 2019 10:19 AM
Bongiorni706
Mar 18, 2019 08:14 AM
tazdevil02
Dec 1, 2016 02:26 AM
rlfxdwg11
Jun 16, 2012 07:48 PM
